kannanni
  • 82
  • 12
Message 1 of 23
poor speed
currently experiencing intermittent speeds and not sure what has changed. Please see my stats from the hub and let me know if you notice anything wrong.
13310000004.340256 qam25
2251000000340256 qam15
32590000003.240256 qam16
42670000003.540256 qam17
52750000003.240256 qam18
62830000003.540256 qam19
72910000003.740256 qam20
82990000004.138256 qam21
93070000003.740256 qam22
103150000003.740256 qam23
113230000003.740256 qam24
123390000004.340256 qam26
13347000000440256 qam27
143550000003.540256 qam28
153630000003.940256 qam29
163710000004.140256 qam30
173790000004.340256 qam31
18387000000440256 qam32
193950000004.340256 qam33
204030000004.540256 qam34
21411000000540256 qam35
224190000004.840256 qam36
234270000004.540256 qam37
244350000004.140256 qam38
kannanni
  • 82
  • 12
Message 2 of 23
Re: poor speed
1Locked40.3423
2Locked40.9360
3Locked40.9180
4Locked40.3360
5Locked40.9420
6Locked40.9460
7Locked40.32014
8Locked38.9250
9Locked40.33039
10Locked40.3230
11Locked40.3425
12Locked40.93313
13Locked40.9400
14Locked40.3500
15Locked40.3350
16Locked40.3318
17Locked40.3310
18Locked40.3330
19Locked40.3350
20Locked40.9340
21Locked40.3230
22Locked40.3360
23Locked40.9460
24Locked40.3350
kannanni
  • 82
  • 12
Message 3 of 23
Re: poor speed
15370001941512064 qam2
23940000041512064 qam4
34620001241512064 qam3
46030000441512064 qam1
1ATDMA0020
2ATDMA0010
3ATDMA0030
4ATDMA0000
kannanni
  • 82
  • 12
Message 4 of 23
Re: poor speed
26/12/2021 07:17:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2021 08:50:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 17:32:43noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2021 17:32:43ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2021 22:51:24criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2021 16:47:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/12/2021 16:47:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/12/2021 02:08:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/12/2021 20:39:27noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/12/2021 20:39:27ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/12/2021 10:16:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/12/2021 23:55:7noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/12/2021 23:55:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/12/2021 12:00:5criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2021 22:22:47noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2021 18:19:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/12/2021 07:58:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2021 03:50:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2021 03:50:51Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/12/2021 03:49:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
kannanni
  • 82
  • 12
Message 5 of 23
Re: poor speed
Hub 3.0 device information
The information below shows current status of this Hub 3.0.
Standard specification compliant: DOCSIS 3.0
Hardware version: 10
Software version: 9.1.1912.304
Cable MAC address
Cable modem serial number
System up time: 5 days 13h:40m:39s
Network access: Allowed
kannanni
  • 82
  • 12
Message 6 of 23
Re: poor speed
broadband quality monitor link
bqm
  • 6.09K
  • 512
  • 1.57K
Message 7 of 23
Re: poor speed
All stats and the BQM are looking okay.  Are you connecting wired or wifi ?
kannanni
  • 82
  • 12
Message 8 of 23
Re: poor speed
I’m connected wired via cat 6. Hub is in modem mode.
Post RS Errors from my stats are they ok?
  • 6.09K
  • 512
  • 1.57K
Message 9 of 23
Re: poor speed
Ideally there shouldn’t be any. Reboot the Hub and keep an eye on them. If they build up quickly there is a possible noise issue on the line.
If you are in modem mode what Router are you using?
kannanni
  • 82
  • 12
Message 10 of 23
Re: poor speed
I'm using an ASUS ac68u for years now same setup, its only since they did some work in our area - end of November when I started to notice degradation.
Received an e-mail the other day from VM offering me a free upgrade to hub 5 which I accepted and is due to be delivered on the 6th of Jan - I hope that hub on modem mode will take me to the new DOCSIS 3.1 and improve things? I'm on the 350 meg package though and not sure if I qualify?
I have powered off and rebooted everything as advised and will keep an eye on the Post RS Errors.
