goport
  • 15
poor speed and disconnection issues
We are having very bad connection issues. My wife and I both work from home and are suffering frequent disconnections on internet calls and general work. The same issues occur over Ethernet and wi-fi which makes work nearly impossible. Using a VPN had no impact on results either.
I have reset the hub, restarted it etc. I have checked connections, and everything seems ok. But calls are constantly being interrupted making any form of customer service incredibly difficult and frustrating.
Download speeds are typically between 20-50Mbps and upload is mainly below 0.5Mbps.
Any help, contact numbers etc would be appreciated.
SamKnows :
Latency 17.4 ms
Jitter 1.57 ms
Download 39.6 Mbps
Upload 298 Kbps
 BQM
goport
  • 15
Re: poor speed and disconnection issues
Ookla Speedtest results.
TEST_DATE
DL Mbps
UL Mbps
LAT MS
SERVER
DIST
MODE
SERV
01/22/2021 9:36
24.21
0.16
14
Salisbury
50
multi
4
01/22/2021 9:35
59.89
0.9
19
Salisbury
50
multi
4
01/22/2021 9:33
94.01
2.21
14
Brentford
50
multi
4
01/22/2021 9:32
60.38
12.83
18
Brentford
50
multi
4
01/22/2021 9:31
40.61
0.69
13
Brentford
50
multi
4
01/22/2021 0:19
55.19
0.32
14
Salisbury
50
multi
4
01/21/2021 22:27
33.05
0.2
13
Brentford
50
multi
4
01/21/2021 22:17
30.53
0.14
14
Brentford
50
multi
4
01/21/2021 22:16
37.17
0.14
13
Brentford
50
multi
4
01/21/2021 21:22
41.8
0.29
12
Brentford
50
multi
4
01/21/2021 17:37
70.23
3.37
14
Brentford
50
multi
4
01/21/2021 16:36
32.15
0.2
13
Brentford
50
multi
4
01/21/2021 16:35
44.84
0.1
13
Salisbury
50
multi
4
01/21/2021 15:15
39.67
1.77
14
London
50
multi
4
01/21/2021 14:40
29.77
0.04
14
London
50
multi
4
01/21/2021 11:55
28.13
0.34
15
London
0
multi
4
01/21/2021 11:51
16.1
11.64
19
London
0
multi
4
01/21/2021 11:48
22.55
0.26
17
Brentford
0
multi
4
goport
  • 15
Cable Modem Status
Item
Status
Comments
138750000
Locked
Ranged Upstream Channel (Hz)
53700000
Locked
Provisioning State
Online
Downstream
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
138750000
-7
36
256 qam
1
2
146750000
-6.7
37
256 qam
2
3
154750000
-7.2
36
256 qam
3
4
162750000
-7
36
256 qam
4
5
170750000
-6.5
37
256 qam
5
6
178750000
-6.5
37
256 qam
6
7
186750000
-6.5
37
256 qam
7
8
194750000
-6.5
37
256 qam
8
9
202750000
-6.4
37
256 qam
9
10
210750000
-6
37
256 qam
10
11
218750000
-6.2
37
256 qam
11
12
226750000
-6.2
37
256 qam
12
13
234750000
-6
37
256 qam
13
14
242750000
-6
37
256 qam
14
15
250750000
-6
37
256 qam
15
16
258750000
-6
37
256 qam
16
17
266750000
-5.7
37
256 qam
17
18
274750000
-5.2
37
256 qam
18
19
282750000
-5.4
37
256 qam
19
20
290750000
-5.5
37
256 qam
20
21
298750000
-5.7
37
256 qam
21
22
306750000
-5.7
37
256 qam
22
23
314750000
-5
37
256 qam
23
24
322750000
-5
37
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
36.1
1068945
1673508
2
Locked
37
2095357
425178
3
Locked
36.6
1527467
2091938
4
Locked
36.8
1366668
2483156
5
Locked
37.6
763117
28361
6
Locked
37.3
1924017
1897915
7
Locked
37.3
1996899
1621365
8
Locked
37.6
6920
34
9
Locked
37.3
3494
0
10
Locked
37.3
2433
1
11
Locked
37.6
2728
2
12
Locked
37.6
2602
0
13
Locked
37.3
3293
6
14
Locked
37.6
4320
15
15
Locked
37.6
3304
59
16
Locked
37.6
3528
105
17
Locked
37.3
3417
114
18
Locked
37.6
5122
99
19
Locked
37.6
7448
45
20
Locked
37.6
6205
0
21
Locked
37.6
4099
0
22
Locked
37.6
1403
0
23
Locked
37.6
68
0
24
Locked
37.3
62
0
goport
  • 15
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700000
43
5120
64 qam
6
2
60300000
43.3
5120
64 qam
5
3
39400000
42.5
5120
64 qam
8
4
46200000
42.5
5120
64 qam
7
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
5
0
2
ATDMA
0
0
5
0
3
ATDMA
0
0
3
0
4
ATDMA
0
0
1
0
Time
Priority
Description
22/01/2021 09:14:42
critical
No Ranging Response received - T3 time-out;
22/01/2021 09:13:43
Warning!
RCS Partial Service;
22/01/2021 09:13:21
critical
22/01/2021 09:11:27
Warning!
22/01/2021 09:11:16
critical
SYNC Timing Synchronization failure - Loss of Sync;
22/01/2021 09:11:2
Warning!
22/01/2021 09:09:40
critical
22/01/2021 09:05:44
Warning!
22/01/2021 09:05:31
critical
22/01/2021 09:03:18
Warning!
22/01/2021 09:03:10
critical
22/01/2021 09:00:3
Warning!
22/01/2021 08:59:51
critical
22/01/2021 08:58:25
Warning!
22/01/2021 08:58:7
critical
22/01/2021 08:56:3
Warning!
22/01/2021 08:55:24
notice
LAN login Success;
22/01/2021 08:53:48
Warning!
22/01/2021 08:53:43
critical
22/01/2021 08:52:26
Warning!
