zubbybear
poor broadband speed
hi, getting really poor speeds, in the room with the hub 24.4 mbs and all the other rooms 4.42 mbs. have tried to contact vm but after being put on hold for 32 mins gave up. I have done the reset and done the automated route with vm no change. PLEASE NEED HELP !!!!!!! I work from home and have kids who rely on the broadband for everything.
Anonymous
Not applicable
Re: poor broadband speed
Could you access your router using http://192.168.0.1/ . Don't log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs?
gary_dexter
  • 30.45K
  • 1.88K
  • 4.04K
What speeds do you get wired direct to the hub?
