AzarPlayGames
  • 36
Message 1 of 5
packet loss
i have same problem from december  and finally stop on march, april was fine but this month speed is horrible. i test my broadband in my area it's says no known issue on E9 5PZ. but the speed is so slow lots of packet loss drops, very horrible i, can't watch or browse internet.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f0fabd96d716382b75b5d8dbe6396c04ab...
AzarPlayGames
  • 36
Message 2 of 5
Re: packet loss
Cable Modem Status
Item
Status
Comments
195000000
Locked
Ranged Upstream Channel (Hz)
60300556
Locked
Provisioning State
Online
AzarPlayGames
  • 36
Message 3 of 5
Re: packet loss
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
195000000
-0.5
38
256 qam
8
2
203000000
-0.7
38
256 qam
9
3
211000000
-0.7
38
256 qam
10
4
219000000
-0.7
38
256 qam
11
5
227000000
-1
38
256 qam
12
6
235000000
-1
38
256 qam
13
7
243000000
-1.2
38
256 qam
14
8
251000000
-1.2
38
256 qam
15
9
259000000
-1.7
38
256 qam
16
10
267000000
-1.9
38
256 qam
17
11
275000000
-1.9
38
256 qam
18
12
283000000
-1.7
38
256 qam
19
13
291000000
-1.7
37
256 qam
20
14
299000000
-1.2
37
256 qam
21
15
307000000
-0.9
38
256 qam
22
16
315000000
-0.5
38
256 qam
23
17
323000000
-0.4
38
256 qam
24
18
363000000
-0.2
38
256 qam
25
19
371000000
-0.2
38
256 qam
26
20
379000000
-0.2
38
256 qam
27
21
387000000
-0.2
38
256 qam
28
22
395000000
-0.2
38
256 qam
29
23
403000000
-0.2
38
256 qam
30
24
411000000
0
38
256 qam
31
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.9
71963
13767
2
Locked
38.6
21077
12176
3
Locked
38.6
30674
16406
4
Locked
38.6
20568
17289
5
Locked
38.6
28240
18030
6
Locked
38.6
27651
15906
7
Locked
38.6
17475
14810
8
Locked
38.6
12364
14780
9
Locked
38.6
11375
14915
10
Locked
38.6
17206
15056
11
Locked
38.9
15454
15084
12
Locked
38.6
7186
14696
13
Locked
37.6
7320
15231
14
Locked
37.3
8842
10652
15
Locked
38.6
5533
10229
16
Locked
38.9
5238
10347
17
Locked
38.6
2693
9498
18
Locked
38.9
1208
9741
19
Locked
38.6
1696
10066
20
Locked
38.6
2013
10022
21
Locked
38.6
1891
7516
22
Locked
38.6
3452
19430
23
Locked
38.6
3836
18374
24
Locked
38.9
3215
16035
AzarPlayGames
  • 36
Message 4 of 5
Re: packet loss
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
60300556
4.096
5120
16 qam
1
2
39399776
4.046
5120
16 qam
4
3
46200307
4.046
5120
16 qam
3
4
53700231
4.071
5120
16 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
AzarPlayGames
  • 36
Message 5 of 5
Re: packet loss
Time
Priority
Description
12/05/2020 16:53:39
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 16:46:2
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 16:16:51
critical
12/05/2020 16:08:33
Error
12/05/2020 15:10:0
critical
12/05/2020 14:53:35
Error
12/05/2020 14:26:45
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 14:26:41
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 14:26:41
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/05/2020 14:26:40
critical
12/05/2020 13:12:28
critical
12/05/2020 12:23:39
Error
12/05/2020 11:49:47
Warning!
12/05/2020 09:37:18
Warning!
12/05/2020 09:37:15
critical
12/05/2020 09:37:15
Warning!
12/05/2020 09:37:14
critical
12/05/2020 09:37:14
Warning!
12/05/2020 07:24:12
critical
12/05/2020 07:23:47
Error
