bsbai
  • 9
packet loss and ping issues since move
Hello,
I've been having a problem with my virgin media internet speed since I moved to my new home and the VM engineer installed a new hub 3 router. I even upgraded the speed to 200Mb.
When I do an internet speed test, it's usually ok, some times the upload speed reaches the advertised 200Mb. But when I do a traceroute to 8.8.8.8 for example, I get around 70ms ping time to the local gateway (192.168.0.1) and more than 50% packet loss. I am using an Ethernet cable to connect to the router.
can someone help me with this please :
1- is this related to a problem with my new hub 3 or is it that VM internet is just slow in this area ?
2- would an upgrade to 1Gb speed with the new hub 4 help ?
this is the last 3h of my BQM + router stats :
bsbai
  • 9
Re: packet loss and ping issues since move
14027500001.738256 qam30
2202750000-138256 qam9
3210750000-137256 qam10
4218750000-138256 qam11
5226750000-0.738256 qam12
6234750000-0.737256 qam13
7242750000-0.937256 qam14
8250750000-0.538256 qam15
9258750000-0.537256 qam16
10266750000-0.537256 qam17
11274750000-0.438256 qam18
12282750000-0.238256 qam19
13290750000038256 qam20
142987500000.238256 qam21
153067500000.238256 qam22
163147500000.238256 qam23
17322750000138256 qam24
18330750000138256 qam25
193707500001.738256 qam26
203787500001.438256 qam27
21386750000038256 qam28
223947500001.438256 qam29
23410750000238256 qam31
24418750000238256 qam32
1Locked38.93419402
2Locked38.6200433228
3Locked37.6174212831
4Locked38.6164122747
5Locked38.6150012569
6Locked37.6142212316
7Locked37.6132542108
8Locked38.6120672043
9Locked37.6116811827
10Locked37.6110461710
11Locked38.6100251540
12Locked38.692741393
13Locked38.687001295
14Locked38.678101251
15Locked38.971321086
16Locked38.66663959
17Locked38.65970898
18Locked38.95805786
19Locked38.64252525
20Locked38.64833511
21Locked38.65597489
22Locked38.94219443
23Locked38.63203349
24Locked38.93162329
bsbai
  • 9
14620000043.3512064 qam3
23260000042.3512064 qam5
33940000042.3512064 qam4
45370000043.8512064 qam2
1ATDMA00130
2ATDMA00100
3ATDMA00240
4ATDMA00180
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
9834ncxv9873254k;fg87dsfd;kfo
SFID3202
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID3201
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
08/01/2021 15:02:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 14:28:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/01/2021 09:57:14noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 10:27:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 07:33:17noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 07:33:17ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/01/2021 14:00:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/01/2021 20:12:18noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 19:57:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 19:33:16noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/01/2021 19:33:16ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 08:26:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 07:33:15noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/12/2020 07:33:15ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 21:56:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 19:33:14noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 19:33:14ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/12/2020 07:39:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/12/2020 16:18:23noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 08:16:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
bsbai
  • 9
update : this is a snapshot of my BQM for today, can someone help me fix this please ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
bsbai
  • 9
a link to my live BQM :
My BQM
