alchizzy
  • 47
  • 11
Message 1 of 23
old speed
i installed my new hub4 gig1 modem today
still only getting under 350mbps
still on old speed-??????
how long does it take for gig1 speed to kick in on new modem???
Download 328.9 Mbps
Upload 52.7 Mbps
Latency 20.4 ms
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 23
Re: old speed
Can you please
Copy and paste the contents of the Configuration tab onto here, if you get a yellow / straw box warning click the Post button again. .
alchizzy
  • 47
  • 11
Message 3 of 23
Re: old speed
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
a69834ncxv9873254k;fg87ds
SFID
9846
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
9845
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 23
Re: old speed
That is showing that the Hub is configured for 1 Gig.
What speed do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
alchizzy
  • 47
  • 11
Message 5 of 23
Re: old speed
Download 223.9 Mbps
Upload 54.2 Mbps
Latency 19.9 ms
thats wifi on a macbook pro-no lan port on this mac-only wifi
thats slow by any means
was faster on m350 modem
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 23
Re: old speed
I will try again ...
alchizzy
  • 47
  • 11
Message 7 of 23
Re: old speed
i do not have a ethernet connection on my macbook
my macbook pro is wifi only
i will buy a usbc adapter and check this
alchizzy
  • 47
  • 11
Message 8 of 23
Re: old speed
i am going to argos to collect a adapter
will report back later
alchizzy
  • 47
  • 11
Message 9 of 23
Re: old speed
Download
92.5 Mbps
Upload
51.4 Mbps
Latency
19.5 ms
that is website samknows in modem mode and correct equipment and cable
worse than wi fi
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 23
Re: old speed
Is that the real speed test or the basic test ?
This is the recognised test for the 1 Gig service  >> Sam Knows Real Speed <<
