Vandalbulldog
  • 13
Message 1 of 20
new to 1Gbps with D/L speed Issues - Quick Question?
Hi there. I've recently upgraded to 1gig from the old 100mb package and my d/l speed is still the same. I've looked at the speed into the router and it is around 35-38mbps, download db seems to be out of range on some channels.
My question is, can i post the details on here and if proven faulty, would an engineer be raised as a result of forum interaction or am I best to call the Virgin number (which is under some strain due to Covid) and book an engineer that way?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 2 of 20
Re: new to 1Gbps with D/L speed Issues - Quick Question?
What speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 3 of 20
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 20
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
Vandalbulldog
  • 13
Message 5 of 20
Hi there. With a quality CAT 5E i get 35 to 40mbps on PC Side of Sam Knows Real Speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 6 of 20
Can you post all the figures please.
Vandalbulldog
  • 13
Message 7 of 20
No problem at all. I'll do this as soon as I'm home and set up.
Vandalbulldog
  • 13
Message 8 of 20
Vandalbulldog
  • 13
Message 9 of 20
3.0 Downstream channels
26339000000-6.59999837.636276QAM25626
1139000000-1.59999835.779911QAM2561
2147000000-2.00000035.083549QAM2562
3155000000-2.79999935.083549QAM2563
4163000000-2.20000134.345688QAM2564
5171000000-3.50000036.386890QAM2565
6179000000-2.00000036.609653QAM2566
7187000000-3.90000236.386890QAM2567
8195000000-3.50000035.779911QAM2568
9203000000-5.59999834.925610QAM2569
10211000000-4.00000034.483570QAM25610
11219000000-6.79999924.684271QAM25611
12227000000-6.20000131.136440QAM25612
13235000000-6.29999937.355988QAM25613
14243000000-5.29999937.636276QAM25614
15251000000-5.20000136.609653QAM25615
16259000000-5.90000237.355988QAM25616
17267000000-5.79999936.609653QAM25617
18275000000-10.00000034.483570QAM25618
19283000000-8.09999835.595078QAM25619
20291000000-9.00000034.925610QAM25620
21299000000-7.50000036.386890QAM25621
22307000000-7.20000136.609653QAM25622
23315000000-7.70000136.609653QAM25623
24323000000-7.00000037.355988QAM25624
25331000000-7.29999937.355988QAM25625
27347000000-7.70000137.355988QAM25627
28355000000-7.00000037.355988QAM25628
29363000000-8.20000137.636276QAM25629
30371000000-7.90000237.636276QAM25630
31379000000-8.79999937.355988QAM25631
26Locked000
1Locked1941863401253870
2Locked526056133558492018
3Locked616503191820890
4Locked618389921291090
5Locked61543294190
6Locked56782535140
7Locked61252780160
8Locked361479623460
9Locked366367281330
10Locked5507372130
11Locked363829626789938527
12Locked360809589705354
13Locked35991204110
14Locked35987957320
15Locked35613210217310
16Locked38078647140
17Locked3807486420
18Locked38210039290
19Locked38102086160
20Locked31934357170
21Locked3823166600
22Locked3820703100
23Locked3811284500
24Locked6629501900
25Locked6644439700
27Locked6604669000
28Locked6637193200
29Locked6655695900
30Locked6663908900
31Locked232687079900
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159804K1560QAM4096392
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked -9.823601325637
Vandalbulldog
  • 13
Message 10 of 20
3.0 Upstream channels
14620000046.5205995120 KSym/sec64QAM1
22580000046.2705995120 KSym/sec64QAM4
33260000045.2705995120 KSym/sec64QAM3
43940000044.7705995120 KSym/sec64QAM2
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
