mikey1244
  • 7
Message 1 of 8
maximising speed on ps4
I have split my frequencies and believe assigned my ps4 to the 5ghz. is there any other way other than ethernet of getting faster speeds through a ps4?
Anonymous
Not applicable
Message 2 of 8
Re: maximising speed on ps4
not really the PS4 doesn;t have 802.11ac its only b/g/n so will never get more than about 100
Anonymous
Not applicable
Message 3 of 8
You could try a powerline adapter, like below, which uses power sockets to transmit data through your power lines, however it can be as unreliable as Wifi
https://www.argos.co.uk/product/9156900
For £35 it's worth a go. You could always return it!
jhuk
  • 2.99K
  • 52
  • 286
Problem sorter
Message 4 of 8
Make sure 5GHZ is set to 80 to get Max Link Speed of 866 it has a habit of reverting to 40 which means a Link Speed of 433 when HUB reboots (during the night due to VM working on network etc not just by end user).
dev01958
  • 27
Message 5 of 8
Have a look at setting up a proxy with squid/ccproxy  - you'll need another laptop/PC but your downloads will be 100x quicker.
Anonymous
Not applicable
Message 6 of 8
how will a proxy make the download faster? the network is the limiting factor
gary_dexter
  • 30.32K
  • 1.88K
  • 4.03K
Message 7 of 8
Cos interwebs innit
jhuk
  • 2.99K
  • 52
  • 286
Problem sorter
Message 8 of 8
Just install Download Accelerator Plus and your Downloads will be 1000x faster!
