Quinntence
  • 9
Message 1 of 15
m500 slow speed
Using the hub 3 as a modem connected to a deco p9, using a cat 6 ethernet while being the only one connected I'm seeing 200 - 240 Mbps on speedtest.net and googles speed test. The downstream on the hub 3 concerns me a little. Here is the hub's status:
No issues in the area according to the service checker and when I run a test on the app it says they noticed a problem but it never gets resolved. This is a recent installation and apart from a great first day and one other day with brilliant speeds we've been having subpar speeds.
Quinntence
  • 9
Message 2 of 15
Re: m500 slow speed
475000000
Locked
Ranged Upstream Channel (Hz)
53700000
Locked
Provisioning State
Online
14750000004.140256 qam37
22510000003.240256 qam15
32590000003.740256 qam16
42670000004.640256 qam17
52750000005.340256 qam18
62830000005.540256 qam19
72910000005.640256 qam20
82990000006.140256 qam21
93070000006.340256 qam22
103150000006.440256 qam23
113230000006.540256 qam24
123710000006.540256 qam25
133790000005.640256 qam26
143870000005.140256 qam27
153950000005.140256 qam28
164110000005.140256 qam29
174190000005.340256 qam30
184270000005.340256 qam31
19435000000540256 qam32
20443000000540256 qam33
21451000000540256 qam34
224590000004.840256 qam35
234670000004.540256 qam36
244830000004.140256 qam38
1Locked40.95412
2Locked40.388040
3Locked40.359315
4Locked40.345319
5Locked40.925514
6Locked40.915012
7Locked40.39715
8Locked40.310919
9Locked40.917117
10Locked40.333229
11Locked40.912928
12Locked40.94014
13Locked40.95416
14Locked40.96315
15Locked40.94915
16Locked40.35112
17Locked40.94614
18Locked40.94812
19Locked40.34312
20Locked40.34612
21Locked40.94012
22Locked40.34912
23Locked40.94812
24Locked40.95611
Quinntence
  • 9
Message 3 of 15
Re: m500 slow speed
1537000004.875512064 qam10
2394000074.875512064 qam12
3461999794.875512064 qam11
4603000144.875512064 qam9
3ATDMA0000
4ATDMA0000
31/08/2020 06:48:13ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/08/2020 02:08:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 16:47:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/08/2020 15:19:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 4 of 15
Re: m500 slow speed
carl_pearce
  • 4.73K
  • 402
  • 706
Superstar
Message 5 of 15
Re: m500 slow speed
Considering your stats look ok to troubleshoot I'd suggest turning off the HUB.
With it still in modem mode plug it directly into a PC/laptop instead of your third party router.
Turn on the HUB, wait for it to initialize, then do another speed test.
Quinntence
  • 9
Message 6 of 15
Re: m500 slow speed
Heres the bqm:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/0ba1e8ddb84acb035706822003f16f3a63...
 Will test the network tonight with it in modem mode connected directly.
Quinntence
  • 9
Message 7 of 15
Re: m500 slow speed
My router was blocking wan pings, sorted now so the graph should show proper results soon
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
Message 8 of 15
Re: m500 slow speed
Don't forget to update the BQM with the new IP address when you change to Modem Mode.
Quinntence
  • 9
Message 9 of 15
Re: m500 slow speed
Im still only getting about 200 down and 36.5 up but ping is lower by a millisecond due to not going through the router
Quinntence
  • 9
Message 10 of 15
Re: m500 slow speed
Bump
It's been a few days, no change, constantly getting slow speeds. Should I call virgin media? I'm paying for 500mbps and im not even getting the guaranteed minimum.
