Snowiez
Just joined
m100 speed Slow
The usual speed on my M100 wifi is 70download and 15-20 upload
Recently on my PC the download speed is 15-20 mb and same with the upload
what has happened to me where my Download has gone down so much?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: m100 speed Slow
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: m100 speed Slow
A bit more information is required, please post the following ...
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: m100 speed Slow
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Please do not use screen shots.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
