Jonus
lower speed gig1 speed when used in modem mode with asus gt-ac5300
So I just installed my Asus gt-ac5300 and noticed much slower speeds
prior to using this router, i was getting 950Mb download speed
now I'm lucky if I get over 550mb down
anyone help me narrow down the issue?
cable is currently cat 6 and will be upgraded to cat 7 tomorrow
any ideas??
jb66
  • 12.28K
  • 912
  • 1.79K
Re: lower speed gig1 speed when used in modem mode with asus gt-ac5300
Does your router have any QOS enabled, try disabling things like that
  • 3.2K
  • 249
  • 696
<snip>
SNB reviews suggests this router only has a WAN throughput of approx. 700mb?  So any QOS or NAT acceleration might have a big performance hit.
Cat 6 cable is fine, it's rated to 1GB.
