Tacanel
  • 5
Message 1 of 7
low speed
internet speed is very low and I lose the connection all the time how can I solve this problem?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 7
Re: low speed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 7
Re: low speed
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Tacanel
  • 5
Message 4 of 7
Re: low speed
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13260000045512064 qam
23939991840512064 qam
34620000044.5512064 qam
42579992251512016 qam
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Tacanel
  • 5
Message 5 of 7
Re: low speed
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12027500009.137256 qam9
2138750000836256 qam1
31467500008.936256 qam2
41547500009.337256 qam3
51627500009.637256 qam4
61707500009.837256 qam5
71787500009.637256 qam6
81867500009.837256 qam7
91947500009.538256 qam8
102107500009.337256 qam10
112187500009.538256 qam11
122267500009.537256 qam12
132347500008.837256 qam13
142427500008.537256 qam14
152507500007.837256 qam15
16258750000837256 qam16
172667500007.837256 qam17
182747500007.338256 qam18
192827500007.438256 qam19
202907500007.538256 qam20
212987500007.138256 qam21
223067500007.138256 qam22
233147500007.538256 qam23
24322750000738256 qam24
1Locked37.638291443
2Locked36.3716151143
3Locked36.670691112
4Locked37.326421027
5Locked37.31962959
6Locked37.321231055
7Locked37.323381297
8Locked37.628041326
9Locked38.628681470
10Locked37.634031684
11Locked38.625551653
12Locked37.622541281
13Locked37.620391071
14Locked37.31680763
15Locked37.61595659
16Locked37.61597722
17Locked37.61829963
18Locked37.623961249
19Locked37.628121523
20Locked38.637581881
21Locked38.648781976
22Locked38.641642063
23Locked38.933901606
24Locked
Tacanel
  • 5
Message 6 of 7
Re: low speed
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062+voc-b.cm
Primary Downstream Service Flo
SFID30270
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID30269
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Tacanel
  • 5
Message 7 of 7
Re: low speed
Network LogTime Priority Description
02/01/2021 21:04:16noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 20:32:1Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 20:32:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 19:41:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 19:41:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:27:51noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:08:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:08:52Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:08:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:08:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:08:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:08:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:08:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:08:43Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:08:43criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:06:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:06:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:05:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/01/2021 17:05:56criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
