  • 9
Message 1 of 15
low speed
I should be getting superfast (200) but my speed test says Im inly getting 5 ! Why is this? The website says there is no problem,  but that's evidently a problem.  Any information is appreciated.
  • 14.9K
  • 1.17K
  • 3.48K
Message 2 of 15
Re: low speed
wired or wireless - always test wired
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
  • 9
Message 3 of 15
Re: low speed
Download
1203000000-1.538256 qam9
2139000000038256 qam1
3147000000-0.538256 qam2
4155000000-0.938256 qam3
5163000000-138256 qam4
6171000000-1.538256 qam5
7179000000-1.738256 qam6
8187000000-1.738256 qam7
9195000000-1.738256 qam8
  • 14.9K
  • 1.17K
  • 3.48K
Message 4 of 15
Re: low speed
what you have posted looks ok but there are 24 downstream channels and a second page - there is also the upstream levels
and wired or wireless
Tony
  • 9
Message 5 of 15
Re: low speed
  • Upstream
1537000004.925512064 qam2
2602999804.925512064 qam1
3462002044.8512064 qam3
4394000004.7512064 qam4
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
  • 9
Message 6 of 15
Re: low speed
Ah yes, here's the full downstream metrics
Router status
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
10211000000-1.538256 qam10
11219000000-1.538256 qam11
12227000000-1.738256 qam12
13235000000-1.938256 qam13
14243000000-238256 qam14
15251000000-2.238256 qam15
16259000000-2.438256 qam16
17267000000-2.538256 qam17
18275000000-2.737256 qam18
19283000000-2.538256 qam19
20291000000-2.737256 qam20
21299000000-2.437256 qam21
22307000000-2.738256 qam22
23315000000-2.238256 qam23
24323000000-2.538256 qam24
1Locked38.950
2Locked38.990
3Locked38.6210
4Locked38.6310
5Locked38.6190
6Locked38.6220
7Locked38.660
8Locked38.6100
9Locked38.9120
10Locked38.970
11Locked38.980
12Locked38.9210
13Locked38.6120
14Locked38.9100
15Locked38.680
16Locked38.980
17Locked38.9120
18Locked37.6140
19Locked38.6270
20Locked37.62560
21Locked37.613840
22Locked38.6220
23Locked38.9130
24Locked38.6160
  • 14.9K
  • 1.17K
  • 3.48K
Message 7 of 15
Re: low speed
levels are good - so again how are you testing the speed
Tony
  • 9
Message 8 of 15
Re: low speed
Speed test apps which have been very reliable before. Our video conferencing is grainy and not refreshing quick enough so we are told is jerky ....
  • 9
Message 9 of 15
Re: low speed
Can you translate what those metrics show, in terms of what upload/download speeds you think we are getting?  As mentioned, I'm expecting to see 200 and the speedtests are showing less than 10.  If you can tell me what you think I'm getting, that will help. Thanks
  • 20.96K
  • 1.14K
  • 2.7K
Message 10 of 15
Re: low speed
Again, please answer the question.
Are you Speedtesting wired or wirelessly???
