paul-b
  • 36
Message 1 of 45
low broadband speed
I have just come out of contract and reduced my package from m350 to m200 on a 1 month rolling contract as we intend to move soon to an area that does not have a virgin signal so did not want to be tied in to a contract, I now find that although I am told I now have m200 my speed is constantly below 100mbps, I am posting this on here because we recently had our hub 3 fail but it took me more than 6 hours on hold on 6 calls to virgin to get them to accept the hub 3 was faulty and do not have that sort of time to deal with this.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 45
Re: low broadband speed
Have you had a replacement Hub sent out ?
paul-b
  • 36
Message 3 of 45
Yes and is all set up and working and the speed I received was over 350mbps as we still had part of our M350 running which by the way is due to end on the 19th of this month.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 45
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
paul-b
  • 36
Message 5 of 45
download between 91 and 98mbps, upload around 36mbps on my computer which is the only unit wired to the hub
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 6 of 45
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
paul-b
  • 36
Message 7 of 45
sorry for the slow reply had things to do, 100Mbps.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 8 of 45
That tells us that the cable you are using is either iffy or the wrong spec
or
Your device Network Interface Card (NIC) is not capable or not set correctly.
The easies check is to try a different Cat 5e or better ethernet cable.
If that doesn't work check the Link Speed for the NIC in the device settings.
paul-b
  • 36
Message 9 of 45
I have not had any problem until now and it was quite capable of running 350 + until I changed my package.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 45
Something has changed or the Connection Speed wouldn't be reporting as 100 Mbs.
I have told you the likely cause[s], it is up to you to check them out or sit on 100Mbs.
