garrybuild
  • 7
low broadband speed
 help, have been upgraded to 200Mbps for about 9 m0nths and never recieved more than 110Mbps, but for... help, have been upgraded to 200Mbps for about 9 m0nths and never recieved more than 110Mbps, but for...supposed to receive 200Mbps since upgrade about 9 months ago, but only ever received no more than 110Mbps since upgraded from 100Mbps, for the past month it has been running at about 50Mbps and today ran a think mobile speed test and it returned a download speed of 33.0 Mbps and an upload speed of 2.9 Mbps. the virgin site consistently says there is no problem, have tried the pinhole reset and numerous reboots to no avail, please help me with this problem
nathan_zetec
  • 105
  • 11
  • 10
Up to speed
Re: low broadband speed
Are you running these tests on wired or wireless connections?
what device are you using?
where is the device when running the test (ie same room)
what is the construction of the house (thick stone walls etc)
garrybuild
  • 7
hi Nathan,
thanks for answering me, my computer is HP Pavilion Desktop 590 A0xxx
it is connected to 3.0 super hub that is about 1.5m away, by an Ethernet cable and is in the same room
my house is concrete external walls, plasterboard internal walls
thanks again
gary_dexter
  • 30.46K
  • 1.88K
  • 4.05K
Don’t run wireless speedtests.
Run one wired direct to the hub.
garrybuild
  • 7
hi gary, thanks for your reply
i am running  test wired direct from hub
Zoie_P
  • 2.48K
  • 118
  • 196
Hi Garrybuild,
Thank you for your post I am sorry you are having issues. I have done some remote checks and I can see there are some issues with your wifi, I will pop you over a private message just keep an eye out fro the purple envelope 🙂
Zoie
