on 17-11-2022 14:07
I have virgin M200; Logged in the Speed Mbps column is 457.03 for my phone 761.71 for my iPad with similar high numbers for wife's iPad and phone my computer Ethernet connected shows 1000 number
What do these numbers represent, They surely cannot be Mbps
Reason for asking is that we have interment drop out so just trying to resolve issue. Have spoke to Virgin who had me reset the router but the numbers still the same. I have taken some items off the wifi to see if the drop out stops
Any help appreciated.
Answered! Go to Answer
20-11-2022 09:27 - edited 20-11-2022 09:27
@frnterer wrote:Just to clarify the original post which was not entirely clear, When I log in to the router the connected devices column were giving the numbers I put in the original post
The 'Connected Devices' section shows the speed the device is connected to the HUB, rather than the expected download speed.
Wired devices will show as 100 or 1000 (Or event 2500 for the HUB 5) depending on the type of device connected.
Wireless devices will display various values depending on their capabaility, distance from HUB, etc.
on 17-11-2022 14:19
What are you using to check the speed?
on 17-11-2022 15:18
I am using speedtest. used others and got around the same readings
average results
Download 277 ping 22 634 down arrow
Upload 25.9 jitter ms 2 35 up arrow
By now I am sure you will know I am winging this
thanks
on 17-11-2022 15:23
on 20-11-2022 08:26
Hi @frnterer
If you are getting speeds of that nature, the speeds are fine on the M200 package 🙂
I am sorry however to hear you're experiencing drop outs. I've ran a check here and there seemingly was an issue at the time of the post but there's been no disconnections I can see since Thursday.
I hope that means everything is sorted, however, do pop back if you need our help still
Best wishes,
on 20-11-2022 13:48
Thanks for your reply
So the connected devices numbers shows the speed, of for example my IPad as 761.71 Mbps. This would be the speed of my Ipad connection to the router and does not relate to the download speed from the router to my Ipad.
Thanks again
20-11-2022 13:53 - edited 20-11-2022 13:55
@frnterer wrote:Thanks for your reply
Thanks again
Correct.
Roughly you can work out the expected download speed, which is 2/3 to 3/4 of the connected speed, vs the limit of your broadband speed.
For example my Samsung connects at 433Mbps and I get around 250 - 300Mbps download speed on Gig1.
In your example your iPad is connected at 761.71 Mbps, so should see full download speed on M200.
on 20-11-2022 13:58
Hi Thanks for responding
the problem continues, we still have the network dropping it is a daily occurrence and happens frequently. we have had the issue for some time and when I renewed the contract I went up to M200 thinking this would resolve it and now have the M250 but the download speed looks fine it is that the connection just drops. it is not for long periods but is regularly 3-5minutes and as much as 3 to 7 times an hour.
Any assistance appreciated
20-11-2022 14:01 - edited 20-11-2022 14:01
If you log into your HUB on 192.168.0.1 and access the below section you should be able to copy paste some stats to show if there is anything amiss.
