14-07-2023 10:33 - edited 14-07-2023 10:40
My service has been intermittently poor for the last couple of weeks or so and is degrading. Websites are noticeably slow to load (+/-10 secs). Using an ethernet connection.
Virgin report no issues in my area, but speedtests over 2 days report <3Mbps down, although up is as per my package.
I have run through the self-tests on the Virgin Media broadband page, without finding any problems.
Turning to this forum, rather than trying to call Virgin: well, I wouldn't repeatedly smash myself in the face with a lumphammer, would I?
on 14-07-2023 16:31
Did you try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to street cab/ postcode level.
The "compensation "timer" can also be started on this number if appropriate.
See what is on there and report back
14-07-2023 19:36 - edited 14-07-2023 19:48
Thanks, according to the automated line there are no issues in my area (and no "compensation timer" option).
Checking "service status" from my account page initially tells me there are no issues, but if you follow that up by choosing "still having issues" and select the broadband option, it then tells me there is an "intermittent signal issue".
on 15-07-2023 20:42
It's their DNS: changed to 1.1.1.1 and...
on 16-07-2023 17:50
Hi @HappyHappyHappy thanks for getting back to us.
And thanks for updating us. Based on the screen shot you've posted, do you consider your issue to now be resolved? Remember, if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand. Please bear in mind, you can manage your account from here. Your online account, will give you access to your bills, show your package details, diagnose any possible faults and monitor any orders and appointments you may have.
Lee_R
