gmj22
  • 13
just hard wired Firestick to hub 3.0
The speed check has shown improvement from 50 MB to around 80 Mb but way down on the 200MB package any ideas what the problem could be /
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Re: just hard wired Firestick to hub 3.0
You won't get full speeds on a media stick, even when hardwired.
Anonymous
Not applicable
The Firestick USB ethernet adapters are 100Mbps, not 1000Mbps, so the speeds you are getting are about right.
david_mcleay
  • 6
I believe you can get 3rd party Ethernet adapters to overcome the 100MB limit on Amazon's own brand one - that said above 50MB to firestick be able to play & stream everything you'd want to ? I am going to create a separate post on the topic of alternate Firestick adapters
