Hi there @Irichar0
Thank you so much for your post and I am so sorry to see you are facing these issues with your connection.
I have double checked the Hub on our side and everything appears to be in spec, so we cannot see what could be causing this issue. Can I ask if you are experiencing this loss of connection on wired as well as WiFi devices?
Are you able to do as advised by @jpeg1 and provide us with a BQM? Can you set this up and let it run for 24-48 hours then post the results so we can get a more in depth look into these disconnects?
