KernelFergus
  • 29
Message 1 of 21
intermittent latency spikes until modem/hub 3 reboot
hello all.
fairly recently i have noticed latency spikes, randomly throughout the day, so i wrote a short script from my linux server to log ping times, and what i have found is perplexing.
the ping log i recorded is in the next post,  i exceeded the character limit.
there doesn't seem to be any real pattern to this, during these times the hub is inaccessible or at best extremely slow to respond.
my network setup is unconventional, using a pfsense router machine, and a separate asus router to provide the wifi for our household, with the hub in modem mode (having previously attempted to use it as a router, it was promptly switched back to modem).
the above ping times persist occurring randomly until i reboot the hub, after which it acts perfectly normally for 2-3 days.
currently the hub's admin pages are inaccessible after the recent high pings.
while typing this a speedtest.net result has provided 323Mbps down and 36Mbps up from my desktop pc (core i7 4790k, 24GB ram, 1Gb network ethernet to 1Gb switch, into router, to hub). i have also run tests from a home server (using speedtest.net command line) and have achieved similar results.
here are the readouts from the hub's status pages:
The information below shows current status of this Hub 3.0.
Standard specification compliant: DOCSIS 3.0
Hardware version: 10
Software version: 9.1.1811.401
Cable MAC address: **:**:**:**:**:**
Cable modem serial number: AAAAAAAAAAAA
System up time: 0 days 0h:4m:38s
Network access: Allowed
Item Status Comments
266750000
Locked
Ranged Upstream Channel (Hz)
39399983
Locked
Provisioning State
Online
1266750000-1.238256 qam17
21387500001.738256 qam1
31467500001.738256 qam2
41547500001.538256 qam3
51627500001.438256 qam4
61707500001.538256 qam5
71787500001.438256 qam6
81867500001.438256 qam7
91947500001.240256 qam8
102027500000.938256 qam9
112107500000.538256 qam10
122187500000.538256 qam11
132267500000.238256 qam12
14234750000038256 qam13
15242750000-0.438256 qam14
16250750000-0.538256 qam15
17258750000-1.238256 qam16
18274750000-1.438256 qam18
19282750000-1.238256 qam19
20290750000-0.738256 qam20
21298750000-0.538256 qam21
22306750000-0.438256 qam22
23314750000-0.238256 qam23
24322750000038256 qam24
1Locked38.9120
2Locked38.900
3Locked38.950
4Locked38.960
5Locked38.900
6Locked38.900
7Locked38.960
8Locked38.660
9Locked40.340
10Locked38.660
11Locked38.600
12Locked38.940
13Locked38.650
14Locked38.650
15Locked38.630
16Locked38.940
17Locked38.600
18Locked38.6110
19Locked38.670
20Locked38.9130
21Locked38.950
22Locked38.950
23Locked38.9120
24Locked38.940
1393999834.55512064 qam2
2258000094.55512064 qam4
3326000124.55512064 qam3
4462000124.7512064 qam1
trimmed due to character limit
any help would be greatly appreciated.
KernelFergus
  • 29
Message 2 of 21
Re: intermittent latency spikes until modem/hub 3 reboot
cont:
3ATDMA0000
4ATDMA0000
01/06/2020 23:31:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/05/2020 18:32:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 20:36:8noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 20:36:8ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 17:19:9ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 15:05:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/05/2020 07:28:23ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 18:32:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/05/2020 18:20:41ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/05/2020 03:50:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/05/2020 18:19:19noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/05/2020 02:54:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2020 22:16:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/05/2020 22:16:19Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2020 16:29:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2020 05:13:2noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/05/2020 05:13:2ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2020 22:34:32ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2020 21:07:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/05/2020 15:56:5ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
KernelFergus
  • 29
Message 3 of 21
cont (again):
ping (ms) - date - time
105 21-05 18:38
546 21-05 19:35
225 21-05 20:03
609 21-05 23:48
595 21-05 23:48
636 22-05 01:10
603 22-05 01:10
306 22-05 01:10
604 22-05 05:11
123 22-05 06:32
408 22-05 12:58
443 22-05 12:58
328 22-05 16:10
359 22-05 18:29
109 23-05 05:27
484 23-05 10:35
605 23-05 10:35
571 23-05 13:44
522 23-05 13:44
586 23-05 13:44
527 23-05 13:44
481 23-05 13:44
304 23-05 13:45
143 23-05 20:49
621 23-05 23:18
602 23-05 23:18
600 23-05 23:18
578 23-05 23:18
619 23-05 23:18
101 24-05 07:30
119 24-05 07:30
561 24-05 11:28
631 24-05 11:28
564 24-05 11:28
493 24-05 11:29
609 24-05 11:29
513 24-05 11:29
597 24-05 11:29
593 24-05 11:29
336 24-05 11:29
574 24-05 11:30
436 24-05 11:31
588 24-05 11:31
616 24-05 11:31
560 24-05 11:31
160 24-05 11:48
124 24-05 13:30
184 24-05 13:30
364 24-05 13:30
124 24-05 15:29
397 24-05 15:29
574 24-05 15:30
593 24-05 15:30
583 24-05 15:30
273 24-05 15:30
337 24-05 15:30
259 24-05 15:30
165 24-05 15:44
136 24-05 15:44
309 24-05 15:44
322 24-05 15:44
360 24-05 15:44
312 24-05 17:30
322 24-05 17:30
219 24-05 17:30
604 24-05 17:31
383 24-05 17:31
117 24-05 17:31
437 24-05 17:31
509 24-05 18:00
556 24-05 18:00
592 24-05 18:00
446 24-05 18:00
136 25-05 15:33
107 25-05 16:37
126 25-05 17:02
153 25-05 17:11
579 25-05 18:35
492 26-05 12:58
409 26-05 14:48
625 26-05 14:48
555 26-05 14:48
106 26-05 14:49
108 26-05 19:44
106 27-05 03:01
125 27-05 12:41
146 27-05 14:48
316 27-05 15:01
121 27-05 15:28
185 27-05 20:43
253 28-05 07:16
114 28-05 08:01
572 28-05 16:20
236 28-05 22:33
347 28-05 22:33
631 28-05 22:33
513 28-05 22:33
531 28-05 22:33
614 28-05 22:33
513 28-05 22:34
259 28-05 22:34
593 29-05 02:01
633 29-05 02:02
257 29-05 02:02
526 29-05 02:02
405 29-05 02:02
545 29-05 02:02
640 29-05 10:04
537 29-05 14:02
614 29-05 14:02
537 29-05 14:02
158 29-05 18:34
168 30-05 00:06
170 30-05 00:06
134 30-05 00:06
116 30-05 22:36
120 31-05 13:42
224 31-05 15:38
184 31-05 16:01
133 31-05 16:02
233 31-05 16:04
118 31-05 16:05
187 31-05 16:08
154 31-05 17:10
137 31-05 17:10
222 31-05 17:11
103 31-05 17:11
211 31-05 17:12
172 31-05 17:13
106 31-05 17:17
166 31-05 17:17
151 31-05 17:18
145 31-05 17:18
179 31-05 17:19
193 31-05 17:25
102 31-05 17:26
109 31-05 17:26
104 31-05 17:33
108 31-05 17:33
133 31-05 17:34
158 31-05 17:34
215 31-05 17:35
197 31-05 17:36
175 31-05 17:36
108 31-05 17:37
238 31-05 17:37
238 31-05 17:38
263 31-05 17:39
173 31-05 17:39
193 31-05 17:41
133 31-05 17:41
186 31-05 17:41
120 31-05 17:42
324 31-05 17:42
305 31-05 17:42
561 31-05 17:42
482 31-05 17:42
621 31-05 17:43
503 31-05 17:43
228 31-05 17:43
331 31-05 17:43
470 31-05 17:43
498 31-05 17:43
343 31-05 17:43
332 31-05 18:15
138 31-05 18:28
115 31-05 18:30
152 31-05 18:30
105 31-05 18:37
643 31-05 20:27
116 31-05 21:50
166 31-05 22:14
470 01-06 01:26
485 01-06 01:26
279 01-06 01:27
521 01-06 03:38
631 01-06 03:38
504 01-06 03:38
582 01-06 13:49
590 01-06 13:49
518 01-06 13:49
451 01-06 13:49
315 01-06 13:49
601 01-06 13:50
270 01-06 13:50
333 01-06 18:44
508 01-06 18:44
572 01-06 18:44
519 01-06 18:44
512 01-06 18:44
583 01-06 18:44
613 01-06 18:44
115 01-06 19:53
128 01-06 19:56
486 01-06 20:27
560 01-06 22:00
600 01-06 22:00
383 01-06 22:00
393 01-06 22:00
207 01-06 22:06
171 01-06 22:06
225 01-06 22:32
313 01-06 22:32
401 01-06 22:32
504 01-06 22:33
136 01-06 22:33
364 01-06 22:34
437 01-06 22:34
200 01-06 22:34
398 01-06 22:35
308 01-06 22:35
608 01-06 22:42
530 02-06 00:28
Beth_G
  • 3.09K
  • 195
  • 301
Message 4 of 21
Hi KernelFergus,
I'm sorry to hear that you've been having some issues with your broadband service.
I've had a look at the back end of your services and there doesn't seem to be any real issues that could be causing the instability.
Can you please confirm if you are still experiencing problems today or whether there has been any improvements since posting?
Kindest regards,
Beth
KernelFergus
  • 29
Message 5 of 21
hi Beth_G.
last night didnt seem to have any major issues, but the time it most often happens is when im talking with my friends online or one of us is playing online games, neither of which happened last night.
however, when i created the thread i started a TBB quality monitor and it shows some scattered spikes, some of which are quite high:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ca370060d1544a5a9ccdf5d1c067ecbf36667ba6-04-06-2020
 my custom script only pings once every 5 seconds, so it may be missing some of the peaks that the TBB monitor catches.
also, i rebooted it just before i posted this thread and its is usually better for 1-2 days after rebooting.
KernelFergus
  • 29
Message 6 of 21
EDIT: just to add, i checked the TBB monitor this evening, and there is a severe spike at around 1515 in the afternoon, bad enough that some packets were actually lost:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ca370060d1544a5a9ccdf5d1c067ecbf36...
KernelFergus
  • 29
Message 7 of 21
further update: the ping spikes are still happening, so just to attempt to eliminate another variable, i switched from pfsense to an older (but still capable) asus router.
here is the chart from the time i switched the router (the large packet loss block is the time i switched):
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b501c64befeb7197a1a43d75186256f0e4...
Bestie
  • 495
  • 9
  • 94
Fibre optic
Message 8 of 21
I'm having the same issue as you I can't access the modem page until I reboot it and the ping spikes look the same too.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b9024ce457df2a39e17f548036e3f36dde559526
KernelFergus
  • 29
Message 9 of 21
it appears that switching router has not changed anything regarding this issue (i didnt believe it would) and switching to a less capable router actually appears to have worsened ping times on the whole, but by very little.
here is a link to the chart that i have captured in the last 24 hours:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/52db628b0565c1e4c3ab51bf202d0ca674...
i have also captured an image of the chart and annotated the suspect areas:
circled in blue is the packet loss that results
circled in white is the suspect ping spike. note the dramatic increase in average but no increase in minimum.
circled in pink is a strange DECREASE in minimum ping, a small increase in the average and a large increase to the maximum around the time of the dramatic jump iump in pings.
Steven_L
  • 4.62K
  • 338
  • 458
Message 10 of 21
I have been able to look into your account KernelFergus and cant see anything that would be causing the issues with the ping spikes.
How has your connection been running since you last posted on Sunday?
Steven_L
