polaar
  • 15
Message 1 of 8
intermittent connection hiccups
Since yesterday i am having latency spikes,  getting constantly connection to server lost messages in games around every half hour or so.I am using wired connection and are the only person on the connection.https://www.thinkbroadband.com/broadband/monitoring/quality/share/48f6de05535404c0b7f46acbd88cced331...
I tried to reset the modem but nothing changed so i started to use BQM this morning to see whats happening. Any idea what causes this? The service status shows no faults in my area,and have no programs running in the background.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 8
Re: intermittent connection hiccups
Go round all the accessible co-ax connections and ensure that they are finger tight.
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
polaar
  • 15
Message 3 of 8
Refresh data
1 298750000 -8.5 37 256 qam 21
2 138750000 -3.5 38 256 qam 1
3 146750000 -4 38 256 qam 2
4 154750000 -4.5 38 256 qam 3
5 162750000 -5.4 38 256 qam 4
6 170750000 -5 38 256 qam 5
7 178750000 -5 38 256 qam 6
8 186750000 -5.7 38 256 qam 7
9 194750000 -6.2 38 256 qam 8
10 202750000 -6.5 38 256 qam 9
11 210750000 -6.2 38 256 qam 10
12 218750000 -6.5 38 256 qam 11
13 226750000 -7.2 37 256 qam 12
14 234750000 -7.2 38 256 qam 13
15 242750000 -7.5 38 256 qam 14
16 250750000 -7.5 38 256 qam 15
17 258750000 -8 37 256 qam 16
18 266750000 -8.2 38 256 qam 17
19 274750000 -8.2 38 256 qam 18
20 282750000 -8.4 38 256 qam 19
21 290750000 -8.2 38 256 qam 20
22 306750000 -7.9 38 256 qam 22
23 314750000 -8.4 37 256 qam 23
24 322750000 -8 37 256 qam 24
1 Locked 37.6 2114 85316
2 Locked 38.9 9875 74486
3 Locked 38.6 20564 74600
4 Locked 38.9 14278 74800
5 Locked 38.9 8902 75014
6 Locked 38.9 11559 73595
7 Locked 38.9 8598 73854
8 Locked 38.6 8431 73497
9 Locked 38.6 5814 73453
10 Locked 38.6 5618 81220
11 Locked 38.9 17818 61753
12 Locked 38.6 2128 79995
13 Locked 37.6 2443 80602
14 Locked 38.9 1624 79322
15 Locked 38.6 1280 79195
16 Locked 38.9 1295 71431
17 Locked 37.6 3299 75124
18 Locked 38.6 8064 78120
19 Locked 38.9 11035 75624
20 Locked 38.6 13321 73545
21 Locked 38.6 22259 56667
22 Locked 38.9 2484 76166
23 Locked 37.6 2493 79754
24 Locked 37.6 2345 86497
Refresh data
1 60299957 5.1 5120 64 qam 9
2 39399952 4.9 5120 64 qam 12
3 46200009 4.9 5120 64 qam 11
4 53700009 5.1 5120 64 qam 10
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Refresh data
13/08/2020 12:41:44 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 12:41:43 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 12:41:43 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:39:8 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:39:7 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:20:58 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:20:57 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:19:49 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:19:49 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:19:48 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:07:48 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:07:45 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:07:45 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 10:07:44 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 08:41:38 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/08/2020 08:41:36 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Anonymous
Not applicable
Message 4 of 8
@polaar wrote:
Refresh data
Refresh data
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
Refresh data
Most of your downstream power levels are out of spec (In spec is -6 to +10).
Your upstream power levels are too high, or close to the acceptable level.
VM need to investigate further.
polaar
  • 15
Message 5 of 8
I tried to call them but gave up after a looooong wait, any chance to get in touch with them here on the forums?
Anonymous
Not applicable
Message 6 of 8
The VM staff on here do respond to threads, however it can take a day or two depending on active threads.
Bumping won't help FYI as it's prioritised on last post.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 8
All your power levels are bad and require an engineer visit to get them sorted.
You can contact VM to report your problem using ...
Text service on 07533051809
150 from Virgin landline.
0345 454 1111 from any other UK  phone.
The best time to call is 08:00 to get a UK agent, anything after 10:00 you must realise that you are quite likely to get through to an offshore agent that doesn't speak English as a first language.
Or you can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
John_GS
  • 8.7K
  • 476
  • 769
Message 8 of 8
Hi polaar
I am sorry to hear of the broadband issues. I can see like the community has advised, the power levels are out of spec, which does need a technician.
I'll send you a PM to arrange.
Kind regards,
John_GS
