on 24-05-2023 08:46
I got my new hub 5 yesterday, installed it OK everything seemed to work except when I ran samknows with a wired connection to my pc I got download of 189Mbps, upload 106Mbps. Rebooted hub several times but no improvement.
on 24-05-2023 12:24
on 24-05-2023 12:31
on 24-05-2023 14:17
So it appears the problem is on my side. I inserted a wireless card and disabled the network adapter but no difference. The cat 5 cable is undamaged, I'm stumped, dont know where to go from here.
on 24-05-2023 17:38
After reading up on network cable, I discovered that the cable I'm using is probably not up to the job. I've ordered 20 metres cat 7 as it's quite a long run from router to pc.
24-05-2023 19:22 - edited 24-05-2023 19:22
If it is cat 5, not cat 5e, then you are correct, it's not suitable.
on 24-05-2023 22:18
with any luck the new cable sorts it out, just be careful if you buy it from places like Amazon, make sure its pure copper and doesn't have the words "CCA", it's basically copper-coated aluminium which can cause you other issues, I have been looking for more cat6(or higher) cable recently and Screwfix still does the best cheap cat6 cable, it's what I've used for my entire house, and I have 10gb to 1 location, 2.5 GB to rest of locations.
on 27-05-2023 14:36
Can anyone confirm if this is cat 5 or cat 5e
on 27-05-2023 14:52
Difficult to tell as they look the same:
No markings on the cable?
on 27-05-2023 15:26
No markings on the cable, according to Wikipedia, each of the four pairs in a Cat 5 cable has differing pitch to minimize crosstalk between the pairs. They do appear to all be different twists, which leads me to think it's cat5.
on 29-05-2023 15:42
