Sid786b21
  • 5
hub 4 speeds
i installed my new hub 4 yesterday after upgrading from 500mb to 1tb but i'm receiving exactly the same speeds.can someone plz help.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: hub 4 speeds
What speed do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Sid786b21
  • 5
Re: hub 4 speeds
it says no router found. could that be because it's in modem mode?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: hub 4 speeds
Most certainly.
To do accurate speed tests on the 1Gig service the Hub 4 needs to be in Router Mode.
