paulprescott32
  • 17
Message 1 of 5
hub 3 setting
after a reset from vrigin an telling me its all ok yet im on 2 upstreams which lady on phone telliing me is right.my download speed changes on all 4 ethernet ports an speeds from 35 on port 4 port one 240
Cable Modem
331000000
Locked
Ranged Upstream Channel (Hz)
53700000
Locked
downstream bonded channels
13310000008.540256 qam25
2267000000740256 qam17
32750000007.340256 qam18
42830000007.540256 qam19
52910000007.340256 qam20
62990000006.540256 qam21
73070000006.540256 qam22
83150000006.840256 qam23
93230000007.640256 qam24
10339000000940256 qam26
113470000009.540256 qam27
123550000009.540256 qam28
133630000009.440256 qam29
143710000009.540256 qam30
153790000009.540256 qam31
16387000000940256 qam32
173950000008.840256 qam33
18403000000940256 qam34
194110000009.340256 qam35
20419000000940256 qam36
214270000009.140256 qam37
224350000009.140256 qam38
23443000000940256 qam39
24451000000940256 qam40
1Locked40.950
2Locked40.360
3Locked40.350
4Locked40.350
5Locked40.330
6Locked40.3120
7Locked40.940
8Locked40.310
9Locked40.950
10Locked40.350
11Locked40.350
12Locked40.3190
13Locked40.3150
14Locked40.960
15Locked40.360
16Locked40.350
17Locked40.900
18Locked40.960
19Locked40.360
20Locked40.900
21Locked40.900
22Locked40.940
23Locked40.350
24Locked40.350
15370000042.3512064 qam5
23940000041.8512064 qam8
1ATDMA0010
-tony-
  • 16K
  • 1.26K
  • 3.77K
Message 2 of 5
Re: hub 3 setting
lets forget the lady on the phone - i dont think any areas now have 2 upstreams but not 100% sure
do a full reset and see if things change - hold the button a good 30 sec
____________________
Tony
paulprescott32
  • 17
Message 3 of 5
Re: hub 3 setting
Done all this that's the info after a hard reset. a engineer was booked yet didn't show made some poor excuse.. I been told there should b 4 upstreams an my downstream r all over the place in number terms
-tony-
  • 16K
  • 1.26K
  • 3.77K
Message 4 of 5
Re: hub 3 setting
as i said 4 upstreams are the norm but it depends on the area or did - the people here will confirm
your downstream levels are fine - bit near the top but in limit - dont know on different ports giving different speeds
is that on the same pc just swapping the lan cable from one port to the next - if so try another cable - it could be that
Tony
paulprescott32
  • 17
Message 5 of 5
Re: hub 3 setting
I was hitting over 300 then from weekend it's been dog. Port one on my gaming pc fine but moving down speeds r getting slower. Yea hopefully someone can confirm bout the upstreams as I always thought meant b 4
