LewisKR3
how long till speed is stable?
Hi. Got virgin fitted today and meant to be 500 fibre. Only currently getting 80-150mbps and it's 10 or so hours after install.
Is this normall or should the speed be closed to 500 by now?
jem101
  • 2.36K
  • 277
  • 1.08K
Re: how long till speed is stable?
The system runs at the proper rated speed as soon as it is activated - did the installer not check the speed and status of the router before leaving? What are you using to measure the speed, connected via WiFi or via a cable? There are too many additional factors involved to make WiFi a reliable indicator of network connectivity speed, you need to first test with a PC/laptop which has a gigabit capable network interface and a known working cat-5e or better ethernet cable.
If the speed with a wired setup is correct then you have a wifi issue, if it's still slow then it'll be a connectivity issue upstream.
