BigFloppy
  • 92
Dialled in
Message 1 of 13
gig1 speed only around 650mbps...
Hi all,
So I upgraded from 500 to gig1 in November... I have not managed to get over around 650mbps the whole time since upgrading apart from on the initial day when setup (managed to get 900 ish)... It's stable around this level.
Power levels seem ok and yes I am using ethernet.
I've tried with no other devices connected to wifi etc, so it's not an internal issue. It's this speed no matter what time of day.
Is this normal?
VM, perhaps you can PM me and check my line?
I'm quite disappointed as had to pay extra per month to upgrade an only getting around 50-100 mbps faster...
Thank you.
Andrew-G
  • 10.39K
  • 1.66K
  • 4.75K
Message 2 of 13
Re: gig1 speed only around 650mbps...
If you're testing on wifi, then 650 Mbps is the practical limit for an individual device connecting using the 802.11ac standard.  And that's generally only on premium devices, with anything less well specified typcially slower.  To see anything approaching 1 Gbps you'd have to test two fast wifi devices at the same time (should get speeds that add up to roughly 1.1 Gbps if you the tests are actually running concurrently), or test on a PC connected to the hub by ethernet cable, when you should see speeds around 950 Mbps.
BigFloppy
  • 92
Dialled in
Message 3 of 13
Thanks for the response.
No it's not on Wifi, its wired, CAT6, via my ASUS RT-AC88U, Superhub in modem mode.
I have run both speed tests on the cabled PC and a wifi device at same time, it halves on both of them adding up to the approx 650mbps
I have also tried directly into superhub, non modem mode without my Asus router.
carl_pearce
  • 1.42K
  • 91
  • 313
Knows their stuff
Message 4 of 13
Can you post the router status 'Downstream', 'Upstream', and 'Networklog' tab data from your HUB (Will be 192.168.100.1 in modem mode).
Copy paste in text; you will need to split into multiple posts and sometimes click post a second time due to an error that can occur.
Any MAC info will be removed automatically on posting.
BigFloppy
  • 92
Dialled in
Message 5 of 13
253310000002.736.4QAM25625
61790000000.836.4QAM2566
71870000000.736.6QAM2567
81950000000.636.4QAM2568
92030000000.636.4QAM2569
102110000000.436.4QAM25610
112190000000.436.6QAM25611
122270000000.336.4QAM25612
132350000000.336.6QAM25613
14243000000036.6QAM25614
15251000000-0.236.6QAM25615
162590000000.536.6QAM25616
172670000000.837.4QAM25617
182750000001.337.4QAM25618
192830000001.537.4QAM25619
202910000001.637.4QAM25620
212990000001.937.4QAM25621
223070000002.137.4QAM25622
233150000002.136.6QAM25623
243230000002.436.6QAM25624
263390000002.936.6QAM25626
273470000003.136.6QAM25627
283550000003.136.6QAM25628
293630000003.236.6QAM25629
303710000002.836.4QAM25630
313790000001.836.4QAM25631
323870000001.436.4QAM25632
333950000001.336.4QAM25633
344030000001.236.6QAM25634
354110000001.536.6QAM25635
364190000001.536.4QAM25636
3.0 Downstream channels
25Locked36.38689000
6Locked36.38689000
7Locked36.60965300
8Locked36.38689000
9Locked36.38689000
10Locked36.38689000
11Locked36.60965300
12Locked36.38689000
13Locked36.60965300
14Locked36.60965300
15Locked36.60965300
16Locked36.60965300
17Locked37.35598800
18Locked37.35598860
19Locked37.35598800
20Locked37.35598800
21Locked37.35598800
22Locked37.35598800
23Locked36.60965300
24Locked36.60965300
26Locked36.60965300
27Locked36.60965370
28Locked36.60965300
29Locked36.60965300
30Locked36.38689000
31Locked36.38689010
32Locked36.38689000
33Locked36.38689000
34Locked36.60965300
35Locked36.60965300
36Locked36.38689000
3.1 Downstream channels
37964K1880QAM4096424
37Locked381.735582980
BigFloppy
  • 92
Dialled in
Message 6 of 13
13260000038.35120 KSym/sec64QAM10
23940000038.35120 KSym/sec64QAM9
34620000038.55120 KSym/sec64QAM8
45370000038.85120 KSym/sec64QAM7
3.0 Upstream channels
1US_TYPE_STDMA0010
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
BigFloppy
  • 92
Dialled in
Message 7 of 13
Thu 01/01/1970 00:01:203No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 16/11/2021 19:24:415MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 16/11/2021 19:27:505RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 16/11/2021 19:27:556SW Download INIT - Via Config file cmreg-vmdg640-bbt076-b.cm
Tue 16/11/2021 19:29:096SW download Successful - Via Config file
Tue 16/11/2021 19:31:415MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 16/11/2021 19:57:535MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 16/11/2021 20:56:054DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 20/11/2021 09:08:173No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 22/11/2021 22:31:186CM-STATUS message sent. Event Type Code: 24; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 23/11/2021 20:56:074DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 25/11/2021 04:02:123No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 27/11/2021 08:56:074DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 28/11/2021 20:52:153No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 30/11/2021 18:51:406CM-STATUS message sent. Event Type Code: 24; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 30/11/2021 20:56:074DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 10/12/2021 21:55:233No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 11/12/2021 08:56:084DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 12/12/2021 19:02:465MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 12/12/2021 19:14:265RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 12/12/2021 19:14:326CM-STATUS message sent. Event Type Code: 5; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:193No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 12/12/2021 19:53:355MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 15/12/2021 14:28:314DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 16/12/2021 23:48:273No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 18/12/2021 18:12:304DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 02/01/2022 13:33:113No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 05/01/2022 06:12:304DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 08/01/2022 18:50:405MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
carl_pearce
  • 1.42K
  • 91
  • 313
Knows their stuff
Message 8 of 13
All looks to be in spec.
Can you post the results of the below site:
https://samknows.com/realspeed/
For the above site to work your HUB must be in router mode.
Any QOS enabled on your Asus?
BigFloppy
  • 92
Dialled in
Message 9 of 13
Thanks for this.
So that is testing as it should and also running a speed test using a wifi device and wired device at same time via superhub gives it around the 1.1gbps.
So it's either the asus router not achieving enough throughput or the cable between the superhub and asus router.....
carl_pearce
  • 1.42K
  • 91
  • 313
Knows their stuff
Message 10 of 13
@BigFloppy wrote:
Thanks for this.
Well you will still be limited to 940Mbps due to the 1Gbp ethernet ports.
Any QOS enabled?
Have you tried the speed test built into the ASUS?
