on 03-05-2023 18:38
hi
i'm getting a lot of post rs errors and a couple of things on the logs, I've tightened the coaxial cable going into the hub 5 and checked all the other connections. in a nutshell i would like to get some advice to see if its a noise problem and to see if i need to get an engineer to come out.
03-05-2023 17:46:19 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-05-2023 16:42:31 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-05-2023 14:20:22 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-05-2023 11:23:27 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
03-05-2023 10:19:38 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
02-05-2023 21:33:54 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
02-05-2023 20:30:05 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
02-05-2023 04:49:56 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 18:39:30 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:43:45 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
28-04-2023 17:43:42 | notice | US profile assignment change. US Chan ID: 12; Previous Profile: 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:43:37 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:43:24 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:43:22 | notice | Honoring MDD; IP provisioning mode = IPv4 |
28-04-2023 17:43:16 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:42:28 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:42:16 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:42:15 | warning | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:41:59 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:41:54 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:41:52 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:37:51 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:37:06 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:36:59 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-04-2023 17:36:47 | critical | Cable Modem reset to Factory Default via reset button |
1 | 331000000 | 1.5 | 42 | QAM 256 | 25 |
2 | 211000000 | 2.1 | 42 | QAM 256 | 10 |
3 | 219000000 | 2 | 41 | QAM 256 | 11 |
4 | 227000000 | 1.9 | 42 | QAM 256 | 12 |
5 | 235000000 | 1.9 | 42 | QAM 256 | 13 |
6 | 243000000 | 1.8 | 42 | QAM 256 | 14 |
7 | 251000000 | 2.1 | 42 | QAM 256 | 15 |
8 | 259000000 | 2 | 42 | QAM 256 | 16 |
9 | 267000000 | 2 | 42 | QAM 256 | 17 |
10 | 275000000 | 2 | 42 | QAM 256 | 18 |
11 | 283000000 | 2.2 | 42 | QAM 256 | 19 |
12 | 291000000 | 2.1 | 42 | QAM 256 | 20 |
13 | 299000000 | 2.2 | 42 | QAM 256 | 21 |
14 | 307000000 | 2.1 | 42 | QAM 256 | 22 |
15 | 315000000 | 1.9 | 42 | QAM 256 | 23 |
16 | 323000000 | 1.8 | 42 | QAM 256 | 24 |
17 | 339000000 | 1.4 | 41 | QAM 256 | 26 |
18 | 347000000 | 1.5 | 42 | QAM 256 | 27 |
19 | 355000000 | 1.2 | 42 | QAM 256 | 28 |
20 | 363000000 | 1 | 42 | QAM 256 | 29 |
21 | 371000000 | 1 | 42 | QAM 256 | 30 |
22 | 379000000 | 1.1 | 42 | QAM 256 | 31 |
23 | 387000000 | 1 | 42 | QAM 256 | 32 |
24 | 395000000 | 0.7 | 42 | QAM 256 | 33 |
25 | 403000000 | 0.7 | 42 | QAM 256 | 34 |
26 | 411000000 | 0.5 | 42 | QAM 256 | 35 |
27 | 419000000 | 0.1 | 42 | QAM 256 | 36 |
28 | 427000000 | 0.5 | 42 | QAM 256 | 37 |
29 | 435000000 | 0.1 | 42 | QAM 256 | 38 |
30 | 443000000 | 0.3 | 42 | QAM 256 | 39 |
31 | 451000000 | 0.7 | 42 | QAM 256 | 40 |
1 | Locked | 42 | 13 | 0 |
2 | Locked | 42 | 30 | 52 |
3 | Locked | 41 | 31 | 52 |
4 | Locked | 42 | 41 | 40 |
5 | Locked | 42 | 45 | 31 |
6 | Locked | 42 | 34 | 40 |
7 | Locked | 42 | 30 | 29 |
8 | Locked | 42 | 37 | 17 |
9 | Locked | 42 | 26 | 14 |
10 | Locked | 42 | 36 | 0 |
11 | Locked | 42 | 31 | 0 |
12 | Locked | 42 | 18 | 0 |
13 | Locked | 42 | 17 | 0 |
14 | Locked | 42 | 11 | 0 |
15 | Locked | 42 | 17 | 0 |
16 | Locked | 42 | 16 | 0 |
17 | Locked | 41 | 14 | 0 |
18 | Locked | 42 | 14 | 0 |
19 | Locked | 42 | 12 | 0 |
20 | Locked | 42 | 12 | 0 |
21 | Locked | 42 | 9 | 0 |
22 | Locked | 42 | 10 | 0 |
23 | Locked | 42 | 13 | 0 |
24 | Locked | 42 | 16 | 0 |
25 | Locked | 42 | 14 | 0 |
26 | Locked | 42 | 14 | 0 |
27 | Locked | 42 | 20 | 0 |
28 | Locked | 42 | 39 | 0 |
29 | Locked | 42 | 22 | 0 |
30 | Locked | 42 | 25 | 0 |
31 | Locked | 42 | 27 | 0 |
on 03-05-2023 21:50
As regard to the logs, don’t panic! Read them from the bottom up. You rebooted the hub at 17:36:57 on 28th April (and by the way, the timestamp will seem to be wrong, and that is because the hubs uses UTC time which equates to GMT, but we have changed to British Summer Time, so the time will seem to be one hour behind). Moving on though, the next important event is at 17:43:22, honouring MDD. MDD is Mac Domain Descriptor, which means that the hub has identified the channel that it needs to be listening on to find further configuration information. Now, that does seem to be a bit long time, but for now, shrug and see how it goes.
Anyhow,17:43:45, registration complete, the hub has successfully negotiated its connection with VM’s infrastructure, it’s not some clone and is a genuine VM hub and is now connected. Everything else above that is fine tuning the connection, and everything up to that point can be safely ignored, the initial DOCSIS ranging and registration process is a bit of a mess, and until it has settled down then you can safely ignore all the messages.
However, I’m not too happy about the post RS errors being clustered around the lower frequencies. It does hint of a bit of noise (interference) ingress. But having said that, if your connection is working just fine, then really don’t worry too much about it. The underlying technology is really quite robust and good at working around ‘issues’ such as what you seem to have reported - although said ‘issues’ may just be a transient, and will go away of their own accord!
Now to be perfectly honest, I suspect that if you were to call VM and ask for an tech visit, it is more than likely to be denied, on the grounds that your connection is working within VM’s parameters Or, if one were to turn up, it is more than likely that they will shrug their shoulders, go through the motions of checking connections, and then declare ‘all is well’ and clear off!
Bottom line, what you have posted above, doesn’t actually point to any real fault in your connection at all.
on 03-05-2023 23:17
What you could do is power cycle the hub and post a new set of figures after about 2 hours. This will show the current state of your circuit.
on 04-05-2023 02:15
That's what I've done twice and still get the rs errors, I'll keep an eye on it as atm my connection isn't having any issues. I just wanted to make sure that I don't need to get this sorted.
on 04-05-2023 10:36
A good circuit should have 0 PostRS errors. If there are, and they continue to rise, it needs fixed.
PostRS errors are "un-correctable errors" and they have to be re-transmitted from the sender.
If they continue, I would press VM to send a technician to sort it out.
In the meantime, setup a BQM to record and monitor the state of the incoming circuit www.thinkbroadband.com/ping
on 04-05-2023 23:24
on 08-05-2023 09:29
Hi @johnnyboy98,
Thank you for your posts and welcome back to our community forums. We're here to help.
I'm very sorry to hear that you seem to be having some issues with your broadband connection recently. I've checked over things on our systems and I'm unable to detect any faults currently that would explain this. How are things for you today? Any better?
on 08-05-2023 20:21
Hi Zach and thanks for your reply.
i have posted just above this post that i have had some post rs errors on my hub 5 status page and wanted to know if i need to get them sorted, if i could get your opinion on this it would be greatly appreciated and then i can close this thread on the forum.
thanks again
on 10-05-2023 20:31
Hi johnnyboy98,
Thanks for coming back to us, sorry to see you are facing issues still, I was able to have another look our end and cannot see any issues.
Paul.
on 11-05-2023 00:14
Hi Paul and thanks for getting back to me
While you may not be seeing issues the post rs levels have went up since I last posted and am being told that it's okay to ignore one moment and to get an engineer next. Surly it all should be at 0. Is it possible that someone can give me an honest opinion instead of telling me that there isn't an issue in my area when I can check of this. Also is there a possibility that my area is a classic case of high utilisation.
Thanks john
