simonhunter87
  • 19
Message 1 of 5
frequent drop outs/slow downs - tried ethernet already
hi - i've been trying to resolve this for a while and it's got a lot better since i switched the house to ethernet for computers where i'm working from home/on video calls. but it's still not as good as i'd expect for 100Mbps with no known service issues.
i've done a thinkbroadband monitor as ive seen other posts ask for those...it looks like quite high latency a lot of the time. but not bad packet loss?
i've also copy and pasted the numbers people ask for below - but these don't mean much to me...and i can't find anywhere that tells me what is "normal" vs what is bad/wrong (if anyone has that i'd appreciate it!)
any thoughts? :S
330750000
Locked
Ranged Upstream Channel (Hz)
46200000
Locked
Provisioning State
Online
My Broadband Ping - Virgin Media
simonhunter87
  • 19
Message 2 of 5
Re: frequent drop outs/slow downs - tried ethernet already
13307500004.540256 qam25
22587500003.440256 qam16
32667500003.440256 qam17
42747500003.240256 qam18
52827500003.740256 qam19
62907500003.940256 qam20
7298750000440256 qam21
8306750000440256 qam22
93147500004.340256 qam23
103227500004.540256 qam24
113707500003.540256 qam26
123787500003.240256 qam27
133867500003.240256 qam28
14394750000340256 qam29
154027500002.940256 qam30
164107500002.940256 qam31
174187500002.740256 qam32
184267500002.240256 qam33
19434750000240256 qam34
204427500001.940256 qam35
21450750000240256 qam36
224587500001.740256 qam37
234667500001.240256 qam38
24474750000140256 qam39
1Locked40.9260
2Locked40.3108102
3Locked40.3118107
4Locked40.3140202
5Locked40.3100349
6Locked40.396328
7Locked40.992386
8Locked40.96795
9Locked40.93915
10Locked40.3440
11Locked40.37831
12Locked40.38145
13Locked40.36731
14Locked40.3680
15Locked40.3480
16Locked40.9939112043
17Locked40.3590
18Locked40.9750
19Locked40.9680
20Locked40.9710
21Locked40.3650
22Locked40.3740
23Locked40.91020
24Locked40.91630
14620000044.3512064 qam3
23260000042.3512064 qam5
33940000043.3512064 qam4
45370000044.3512064 qam2
1ATDMA0050
2ATDMA0020
3ATDMA0020
4ATDMA0020
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
,.iyewrkldJKDHSUBsgvca69834nc
SFID384
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID383
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 3 of 5
Your >> BQM << is showing signs of utilisation problems.
Only VM can do anything about utilisation.
You can call in to explain your frequent dropouts.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
simonhunter87
  • 19
Message 4 of 5
Are there any issues with my modem numbers that I've posted? Or is there something I can refer to for what normal numbers/limits are?
simonhunter87
  • 19
Message 5 of 5
i've noticed there always seem to be high post RS errors on down channel 16 - anything i can do about that? would it be causing latency issues?
1Locked40.3280
2Locked40.9114102
3Locked40.3121107
4Locked40.3143202
5Locked40.3106349
6Locked40.399328
7Locked40.392386
8Locked40.37195
9Locked40.94915
10Locked40.9510
11Locked40.38131
12Locked38.98845
13Locked40.37031
14Locked40.3760
15Locked40.3570
16Locked40.31146135171
17Locked40.3650
18Locked40.9810
19Locked40.9790
20Locked40.3780
21Locked40.3680
22Locked40.3850
23Locked40.91190
24Locked40.91840
and quite a lot of T3 errors on the up too?
1ATDMA0050
2ATDMA0020
3ATDMA0020
4ATDMA0030
logs:
Time
Priority
Description
23/11/2020 17:06:45
critical
No Ranging Response received - T3 time-out;CM-MAC=X;CMTS-MAC=X;CM-QOS=1.1;CM-VER=3.0;
23/11/2020 03:15:45
Warning!
RCS Partial Service;CM-MAC=X;CMTS-MAC=X;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 20:34:23
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=X;CMTS-MAC=X;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 13:11:31
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=X;CMTS-MAC=X;CM-QOS=1.1;CM-VER=3.0;
22/11/2020 13:11:31
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=X;CMTS-MAC=X;CM-QOS=1.1;CM-VER=3.0;
21/11/2020 05:45:1
Warning!
21/11/2020 05:26:26
critical
21/11/2020 03:50:5
Warning!
20/11/2020 12:46:41
critical
20/11/2020 02:01:13
Warning!
19/11/2020 16:52:38
notice
19/11/2020 16:52:38
Error
19/11/2020 16:52:36
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=X;CMTS-MAC=X;CM-QOS=1.1;CM-VER=3.0;
19/11/2020 08:26:43
critical
19/11/2020 00:08:57
Warning!
