samedb
fibre optic signal dropping 10 times a day
I'm a new VM customer for both TV + fibre optic and have subscriped to the oomph package, ie 500mb internet + Max TV. I have problems with my TV box (restarting or freezing channels) that i posted in the TV section.
I also have 2 issues with the fibre optic connection
1) I subscribed to the max advertised 500mb but never managed to measure more than 150mb when am lucky. In my office 2 floors up i have a v slow 10 to 50mb, clearly far far from the service sold.
2) On top of that fibre optic connection drops about  7 to 10 times a day and i have to disconnect and connect back again the wifi from my laptop to have it work again.
As im fully working from home these days, it's v annoying to see my work desktop remote connection lost 10 times a day.
Any help please?
Clearly not a happy start with VM to say the least
Thank you
Samed
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: fibre optic signal dropping 10 times a day
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
