praxisone
  • 7
fibre 100 drops out every few days, sometimes for hours at a time
Internet drops out every few days that I notice, maybe it happens more often.
Here is an example today for the last few hours the internet is almost unusable.
These are the router status logs:
12670000002.740256 qam17
2219000000340256 qam11
32270000002.940256 qam12
4235000000340256 qam13
52430000002.740256 qam14
62510000002.740256 qam15
72590000002.740256 qam16
82750000002.540256 qam18
92830000002.540256 qam19
102910000002.238256 qam20
112990000002.240256 qam21
123070000001.538256 qam22
133150000001.238256 qam23
143230000001.238256 qam24
153470000001.238256 qam25
163550000001.238256 qam26
173630000001.238256 qam27
183710000001.440256 qam28
193790000001.538256 qam29
203870000001.538256 qam30
213950000001.938256 qam31
224030000001.938256 qam32
23411000000238256 qam33
24419000000240256 qam34
1Locked40.370
2Locked40.370
3Locked40.340
4Locked40.340
5Locked40.340
6Locked40.300
7Locked40.360
8Locked40.950
9Locked40.350
10Locked38.9130
11Locked40.360
12Locked38.950
13Locked38.640
14Locked38.950
15Locked38.900
16Locked38.960
17Locked38.960
18Locked40.350
19Locked38.960
20Locked38.670
21Locked38.950
22Locked38.950
23Locked38.950
24Locked40.330
13260000033.3512064 qam5
23940000033.3512064 qam4
34620000033.8512064 qam3
45370000033.3512064 qam2
1ATDMA00210
2ATDMA00150
3ATDMA00110
4ATDMA004
0
praxisone
  • 7
Re: fibre 100 drops out every few days, sometimes for hours at a time
23/12/2020 10:09:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 10:08:22noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:19:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:06:59Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:06:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:05:59criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:04:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:03:38criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:01:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 09:01:6criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 08:58:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 08:58:34criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 08:57:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/12/2020 08:56:13criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 15:30:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 15:28:53noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 15:27:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 15:25:28criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 15:24:34criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/12/2020 15:24:33criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Is there anything I can do? Or is this the usual service from virgin?
I just joined in November, so far the frequent drop outs are horrendous.
I also seem to be suffering from the UDP issue in this thread. https://community.virginmedia.com/t5/Speed/UDP-issues-on-SuperHub3-collective-thread/td-p/4382720
I have set my VPN to TCP only which does help, but my internet still frequently is useless.
praxisone
  • 7
This is the BQM for the last 24 hours
e881e567da6c32803e1e1978a4e27c7d827f5399-23-12-2020
  • 26.52K
  • 2.7K
  • 4.92K
Logs and Upstream T3 timeouts are bad news - as is the BQM. You need VM to take a closer look at your connection but I think that will need a tech visit to investigate.
Call it in asap although 08.00 is the best time to get through quickly
