toypadlock
  • 12
Message 1 of 12
extremely slow upload on M350 connection
this has lasted a few weeks - gone from getting steady 35mbps up to between 2-5mbps. have called support several times, but have had to be on hold more than an hour both times and they haven't been able to help. suspect it may be related to this user's issue as we're likely in the same area, but who knows?
everything's wired, and am getting this same issue while directly connected to the router in router mode, though i usually use it in modem mode for obvious reasons.
this was my info before a long (5 minute pause) restart - can see a couple of channels that i think are out of modulation, and a bunch of T3 timeouts, but then this had been up for about a week or so.
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400051
42
5120
16 qam
4
2
46200035
42.5
5120
32 qam
3
3
25799854
40.8
5120
16 qam
6
4
32599985
41.5
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
1
0
2
ATDMA
0
0
5
0
3
ATDMA
0
0
424
0
4
ATDMA
0
0
1
0
here's the same info after restarting and leaving unplugged for five minutes, as seems to be the regular suggestion:
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
39400165
42
5120
16 qam
4
2
46200000
42.3
5120
32 qam
3
3
25800483
41
5120
16 qam
6
4
32600126
41.5
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
1
0
4
ATDMA
0
0
0
0
EDIT: oh, and it might be useful to share my broadband quality thing, so here it is. i only signed up today and then restarted the router a couple of times, so it's not going to be very useful for a while, apologies.
Beth_G
  • 3.42K
  • 213
  • 344
Message 2 of 12
Re: extremely slow upload on M350 connection
Hey toypadlock,
we're really sorry for our delayed reply from here, and for the speed issues you've been experiencing recently.
I've been able to locate your account and have found that you are currently being impacted by an SNR issue in your area, which is estimated to be resolved on 17th November.
Please keep us posting with how things are from Tuesday and let us know if you need anything else from us in the meantime. Sorry for any inconvenience caused.
Kind regards,
Beth
toypadlock
  • 12
Message 3 of 12
Thanks for your response. I wanted to wait for a few days to see how stuff was going before replying. While speeds are very occasionally reasonable, they're super variable and I'm currently getting an upload speed of around 5-8mbps. It's definitely not fixed, I'm afraid. Is there anything that can be done?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 12
Can you please
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 12
toypadlock
  • 12
Message 6 of 12
1331000000538256 qam25
22030000005.638256 qam9
32110000005.338256 qam10
42190000005.538256 qam11
52270000005.538256 qam12
62350000005.538256 qam13
72430000005.138256 qam14
8251000000538256 qam15
92590000004.938256 qam16
102670000004.638256 qam17
11275000000438256 qam18
122830000003.238256 qam19
132910000003.738256 qam20
142990000004.638256 qam21
153070000004.938256 qam22
16315000000538256 qam23
17323000000538256 qam24
183390000005.338256 qam26
193470000005.538256 qam27
203550000005.438256 qam28
213630000005.538256 qam29
223710000005.138256 qam30
23379000000538256 qam31
243870000004.938256 qam32
1Locked38.9500
2Locked38.6390
3Locked38.9360
4Locked38.6520
5Locked38.6500
6Locked38.6580
7Locked38.6330
8Locked38.6410
9Locked38.6370
10Locked38.9520
11Locked38.9800
12Locked38.91230
13Locked38.6620
14Locked38.61310
15Locked38.9380
16Locked38.9260
17Locked38.6300
18Locked38.94122
19Locked38.6520
20Locked38.9450
21Locked38.9450
22Locked38.9210
23Locked38.95158
24Locked38.99412
13939977842512016 qam4
24619989142.5512016 qam3
32580028841512016 qam6
43260014641.5512016 qam5
3ATDMA00500
4ATDMA0000
toypadlock
  • 12
Message 7 of 12
17/11/2020 01:00:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 18:08:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 06:18:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 06:08:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 20:16:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
My Broadband Ping - my home connection
thinkbroadband link
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 12
Your Upstream Channel Modulations are all at 64 QAM, they...
Your Upstream Channel Modulations are all at 64 QAM, they should be at 64 QAM.
You can try a reboot to see if it helps, it may or may not.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check your connection again.
toypadlock
  • 12
Message 9 of 12
Re: Your Upstream Channel Modulations are all at 64 QAM, they...
thanks for the suggestion, but they're all back on 16 qam:
13940061042512016 qam4
24620062042.5512016 qam3
32580004940.8512016 qam6
43259983941.5512016 qam5
3ATDMA0000
4ATDMA0000
Anonymous
Not applicable
Message 10 of 12
3ATDMA0000
4ATDMA0000
In which case you'll need an engineer visit to investigate further, unless there is currently a local area issue.
