on 22-09-2023 20:01
Hi all,
I need help with intermittent speed issues. I'm on a standard 130mbs package. The Hub 3 was terrible so we switched to modem mode and added an Archer AX55 router. Everything has been great for two months and now I get regular drops in speed all the way to 0mbs in the evenings.
I'm testing the speed in wifi via the router, but the trigger for me knowing there is a problem is that the wired PS5 stops mid-use when watching Apple TV or any other streaming service we happen to be using. I used Speed.Cloudfare to check things and I can see fluctuations.
I know how to access the Log but it's only showing upstream timeouts (several). Downstream doesn't show that data. I'm reluctant to change back to router mode to log downstream timeouts as we had so many issues in router mode I can't stand to return to it and have all the disconnects etc that we had before the new router fixed it all.
can anyone help me get to the bottom of evening speed drops etc? I had ZERO issues and no changes in my equipment up until a week ago.
thanks, Matt..
Answered! Go to Answer
on 26-09-2023 19:24
Far too many PostRS errors, usually indicative of a noisy circuit. Reboot the Hub and keep an eye on those errors. A good circuit should have zero errors. If they continue to rise a VM tech will be needed to sort it out.
on 23-09-2023 14:12
In Modem mode we must also consider there may be issue with our network cables and with our router.
Try 0800 561 0061 to see if there is a known fault affecting your street.
Hub Signal Level Check
Via http://192.168.0.1/ connect to the Hub in Router mode, do not login in, scroll down to "Check router status" Use http://192.168.100.1/ for a Hub in Modem mode
Using the Hub's "Check router status" tabs check the Downstream and Upstream power levels are in spec.
Downstream Power Levels of -7 to +7 dBmV are preferred, +10dBmV is the max acceptable, with a SNR of 33dB or higher across all DOCSIS 3.0 channels. Rising error counts across many channels is a current service noise fault.
Upstream Power Levels of 35 to 49 dBmV are preferred, with QAM 64 Modulation mode across all four to six DOCSIS 3.0 channels. Seeing QAM 32/16 is a current service noise fault.
on 23-09-2023 16:41
Test in modem mode with a PC no router then setup a BQM with your router.
on 26-09-2023 18:10
sorry for the delay. this is what I see:
1 | 139000000 | -1.5 | 35 | 256 qam | 1 |
2 | 147000000 | -1.5 | 35 | 256 qam | 2 |
3 | 155000000 | -1.5 | 35 | 256 qam | 3 |
4 | 163000000 | -1.5 | 36 | 256 qam | 4 |
5 | 171000000 | -1.4 | 36 | 256 qam | 5 |
6 | 179000000 | -1.2 | 35 | 256 qam | 6 |
7 | 187000000 | -1.2 | 35 | 256 qam | 7 |
8 | 195000000 | -1.4 | 36 | 256 qam | 8 |
9 | 203000000 | -1.4 | 35 | 256 qam | 9 |
10 | 211000000 | -1.2 | 35 | 256 qam | 10 |
11 | 219000000 | -1.2 | 36 | 256 qam | 11 |
12 | 227000000 | -1 | 36 | 256 qam | 12 |
13 | 235000000 | -1 | 36 | 256 qam | 13 |
14 | 243000000 | -1 | 36 | 256 qam | 14 |
15 | 251000000 | -0.9 | 36 | 256 qam | 15 |
16 | 259000000 | -0.9 | 36 | 256 qam | 16 |
17 | 267000000 | -0.7 | 36 | 256 qam | 17 |
18 | 275000000 | -0.9 | 36 | 256 qam | 18 |
19 | 283000000 | -0.7 | 36 | 256 qam | 19 |
20 | 291000000 | -0.9 | 36 | 256 qam | 20 |
21 | 299000000 | -0.7 | 36 | 256 qam | 21 |
22 | 307000000 | -0.7 | 36 | 256 qam | 22 |
23 | 315000000 | -0.7 | 36 | 256 qam | 23 |
24 | 323000000 | -0.7 | 36 | 256 qam | 24 |
1 | Locked | 35.7 | 57562 | 66978 |
2 | Locked | 35.7 | 37477 | 27882 |
3 | Locked | 35.7 | 5228 | 26721 |
4 | Locked | 36.3 | 4331 | 30397 |
5 | Locked | 36.3 | 4793 | 30389 |
6 | Locked | 35.7 | 4631 | 31645 |
7 | Locked | 35.7 | 4896 | 30550 |
8 | Locked | 36.3 | 4510 | 27574 |
9 | Locked | 35.7 | 4850 | 25805 |
10 | Locked | 35.7 | 5003 | 22718 |
11 | Locked | 36.3 | 4894 | 20275 |
12 | Locked | 36.3 | 5945 | 18087 |
13 | Locked | 36.6 | 5568 | 16457 |
14 | Locked | 36.3 | 4351 | 15880 |
15 | Locked | 36.3 | 4109 | 14884 |
16 | Locked | 36.3 | 4199 | 14615 |
17 | Locked | 36.6 | 4017 | 15024 |
18 | Locked | 36.3 | 4122 | 16170 |
19 | Locked | 36.3 | 4146 | 16783 |
20 | Locked | 36.6 | 4318 | 17530 |
21 | Locked | 36.3 | 4302 | 17941 |
22 | Locked | 36.6 | 4095 | 18320 |
23 | Locked | 36.6 | 4415 | 18927 |
24 | Locked | 36.3 | 4869 | 19368 |
1 | 23599951 | 39.8 | 5120 | 64 qam | 10 |
2 | 39400042 | 39.3 | 5120 | 64 qam | 4 |
3 | 46200034 | 39 | 5120 | 64 qam | 3 |
4 | 32600060 | 39.5 | 5120 | 64 qam | 9 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 4 | 0 |
4 | ATDMA | 0 | 0 | 5 | 0 |
network log contains many critical and error lines.
on 26-09-2023 18:12
some of this is beyond my knowledge so the links aren't any good for me. Also, I don't have a PC. only a MAC.
on 26-09-2023 19:24
on 26-09-2023 20:18
What can cause post RS errors? Would it be a cabling issue inside the property or outside? I know the pre-install job was shoddy and I have a theory that the cable could be susceptible to damage as the installers put it under s slab that is now cracked. its right on top of the cable. Could that be an issue.
Inside the property, the Cat6e from the hub to the router runs parallel with a mains lead. Could this be causing issues or would it need to be a physical connection thing? I can move the Cat6e if that could be part of the problem (that said, its been like this for a couple of months and the problem is new)
on 26-09-2023 22:38
RS errors are often caused by ingress of radio signals on the same band as used by the VM hub. This can be from terrestrial TV, DAB radio, aircraft radios etc. The ingress can sometimes be caused by users on the same street cabinet as you using non-VM coax cables or having an unterminated feed. This type of error is extremely difficult for technicians to find and rectify.
on 27-09-2023 07:28
So when I rebooted my hub I noticed that the co-ax into the hub wasn't threaded up tight, I re-tightened this. indications are good as Post RS errors are remaining at 0, 12 hours later. I will update in due course.
on 28-09-2023 17:50
It's over 48 hours since the reboot and noticing the slightly loose co-ax connection at the rear of the hub. Pleased to say we are reporting 0 PostRS errors and no noticeable drops in speed when streaming content. Fingers crossed that was the issue,
thanks :-_)
