djp1971
  • 14
Message 2 of 5
do not
Do not join this shambles of a company
well virgin media you have done it again
since upgrading my speer to 500mbps the speed i have been getting is crap
i am only getting less than 2 mbps upload
i have tried to contact customer services, been waiting on hold for over 1 hr, when i do finally get through they cut me off,
This issue has been going on for months
also when i have had a look on your website. the 500mbps is not avaiable in my region
so why are you charging me for this???
i look forward to recieving feed back and an update
djp1971
  • 14
Message 1 of 5
do not, i repeat do not join Virgin bloody media
  • 26.34K
  • 2.69K
  • 4.88K
Message 3 of 5
Re: do not, i repeat do not join Virgin bloody media
VM people respond on here but it can take up to a week for them to get to this "Conmmunity Help Forum".
For quicker responses call in at 08.00 in the morning - people are reporting getting through fine then with no long waits.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 5
Re: do not
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 5
Re: do not
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
