nickkellymetal
  • 12
Message 1 of 12
connection timeouts
hey all, does anyone know what the errors below could mean? keep checking area status but says no faults in my area. Connection is very slow and seems to hang. Thanks for help. (using a wired connection direct to hub)
26/10/2020 16:55:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 16:55:4criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 16:48:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 12
Re: connection timeouts
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
nickkellymetal
  • 12
Message 3 of 12
thanks for that just done it and it appears to be the same 😞
I phoned the helpline and the automated voice did say there is a problem in my area although when i check it on the website it says there are no issues? Not sure what to believe.
thanks
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 12
You are having a problem so it should be quite easy to decide which one to believe.
nickkellymetal
  • 12
Message 5 of 12
Well had the messsage to say the fault has been fixed, but haven't been able to get a speed above 80 since (on M200) usually always between 180-200. Tried rebooting the router again and checking all cable connections. Where should i go from here?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 12
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
nickkellymetal
  • 12
Message 7 of 12
graph
nickkellymetal
  • 12
Message 8 of 12
Re: graph
downstream:
13307500007.540256 qam25
22587500007.540256 qam16
3266750000840256 qam17
42747500007.940256 qam18
52827500007.640256 qam19
62907500007.640256 qam20
7298750000840256 qam21
83067500007.340256 qam22
9314750000740256 qam23
upstream
14619999639.5512064 qam3
22580000037.5512064 qam6
33260000039.5512064 qam5
43940000039.5512064 qam4
3ATDMA0010
network logs:
29/10/2020 07:54:4Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:46:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:46:48criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:41:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:41:29criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:22:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:22:50criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:18:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:18:51criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:14:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:14:32criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:11:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:11:51criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:10:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:10:32criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:02:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 09:02:32criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 08:57:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 08:57:13criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 08:55:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
nickkellymetal
  • 12
Message 9 of 12
Re: graph
could anyone have a quick check of my data above? thanks
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 12
Re: graph
You should have 24 Downstream Channels plus another 24 line table in the same tab.
Your BQM is showing all red, can you log into the Hub Settings and set the Hub Firewall to that shown below please ...
Hub-3-Firewall
