05-12-2022 16:15 - edited 05-12-2022 16:22
On February 1st my broadband speed was upgrading from 200mb, to 350mb...as part of an upgrade program.
I don't tend to check my broadband speed because it seems good to me.
Today i used 3 different speed checker website & got 3 different results.
The virginmedia.com speed checker said 100.02mb, the speedtest.net checker said 141.19mb & the proof.ovh.net checker said 142.9mb. So none of them near the 350mb i pay for!virginmedia.com speed checker
proof.ovh.net speed cheacker
I'm now wondering if it's because i only have a Virgin Superhub3. Does that only go upto a certain speed?<- EDIT = I've just checked & there's some kind of internet problem in my area...which is Peterborough.
on 05-12-2022 18:47
on 16-12-2022 01:14
speedtest.samknows.com
speedtest.net
on 16-12-2022 15:36
on 17-12-2022 23:38
Is there a QoS setting in the hub 5? I can't find this setting as I had issues with this in my last isp and turning it off resolved my issues.
on 18-12-2022 10:01
As far as I know QoS does not exist the Hub 5, nor in any Hub.
on 20-12-2022 10:56
Hi geriann,
Thanks for your post and welcome back to the community.
Apologies for any speed problems faced, can I ask are the same readings still present?
Also to double on @jbrennand's question, are devices connected by ethernet affected too?
Let us know,
on 03-01-2023 20:57
on 06-01-2023 08:03
Hi @geriann
Thanks for your response
Are devices connected via ethernet also affected with this issue?
on 06-01-2023 16:47
no everything else seems normal
