Tracyob
  • 23
Message 1 of 22
call out charge
Hello I am having problems wit my wifi i upgraded to m200 and since i have upgraded my speed is even worse so i went onto web chat and spoke to someone who out me through the a tech guy he checked over my account and he advised me to have an engineer out to come and have a look but y question is will i get charged for this call out he is due tomorrow but i do not want to be charged for something that is not my problem
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 22
Re: call out charge
You won't be charged for something that isn't caused by you, if it is something that you have done it could be another matter !!
Just to be clear, VM do not, and never have guaranteed Wi-Fi speed or coverage.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 22
Re: call out charge
If you post some information, we will be able to tell you if there is a VM problem.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 22
Re: call out charge
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Tracyob
  • 23
Message 5 of 22
Re: call out charge
ok thank you
Tracyob
  • 23
Message 6 of 22
Re: call out charge
Router status
331000000
Locked
Ranged Upstream Channel (Hz)
60299998
Locked
Provisioning State
Online
Tracyob
  • 23
Message 7 of 22
Re: call out charge
i can\t log back in it is saying i am already logged into setting but i cannot see where i am logged into any help would be appreciated
Tracyob
  • 23
Message 8 of 22
Re: call out charge
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
13310000002.240256 qam25
2203000000-0.240256 qam9
3211000000-0.240256 qam10
4219000000040256 qam11
5227000000-0.240256 qam12
6235000000040256 qam13
7243000000-0.240256 qam14
82510000000.240256 qam15
92590000000.540256 qam16
10267000000140256 qam17
112750000001.240256 qam18
122830000001.540256 qam19
132910000001.740256 qam20
14299000000240256 qam21
153070000001.740256 qam22
16315000000240256 qam23
173230000002.238256 qam24
183390000002.540256 qam26
193470000002.540256 qam27
203550000002.540256 qam28
213630000002.740256 qam29
223710000002.740256 qam30
233790000002.740256 qam31
243870000002.540256 qam32
1Locked40.3160
2Locked40.3150
3Locked40.3130
4Locked40.350
5Locked40.360
6Locked40.360
7Locked40.390
8Locked40.370
9Locked40.360
10Locked40.350
11Locked40.3170
12Locked40.3180
13Locked40.970
14Locked40.350
15Locked40.970
16Locked40.960
17Locked38.990
18Locked40.9210
19Locked40.9200
20Locked40.9190
21Locked40.9200
22Locked40.970
23Locked40.950
24Locked40.330
Tracyob
  • 23
Message 9 of 22
Re: call out charge
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
16029999842.3512064 qam1
23939997640.8512064 qam4
34620001942.3512064 qam3
45369999642.3512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
Tracyob
  • 23
Message 10 of 22
Re: call out charge
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
9873254k;fg87dsfd;kfoA,.iyewr
SFID17876
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID17875
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
