colmick
  • 8
Message 1 of 7
broadband speed
i have run all the tests reboot, restart hub , hard wire conection.
I upgraded to 200 in march and have never received the broadband speed promised
recently it seems to have got worse, i am aware that more demand is being placed on the service bu what i am getting is not acceptable.
40 -50
this is well below the guaranteed speed
can anyone help
can i get reduction in charges for lack of service
area 20
account   [MOD EDIT: PERSONAL INFORMATION REMOVED]
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 22.51K
  • 2.41K
  • 4.03K
Message 2 of 7
Re: broadband speed
What network card do you have in the laptop/computer you are testing on - is it 1GB enabled or limited to 10/100?
Have you tried a new good quality Cat5e/6 cable?
Also can you do it this way and report back...
Connect the device directly on an ethernet cable (Cat5e/6) connected to a Gb enabled computer/laptop, with up to date drivers with the Hub in MODEM mode. Test at speedtest.net to your nearest VM server - try 2 different browsers.
If they are still low – boot the device into "safe+networking mode" and try again.
colmick
  • 8
Message 3 of 7
Re: broadband speed
done all that but the speed better hard wired 60 but wifi 30-40 disconnected all other boxes only laptop connected modern laptop receive
 far better rates in the past
colmick
  • 8
Message 4 of 7
Re: broadband speed
done most of this
only laptop connected to router
bit better results than wifi
wifi 30 40
hardwire 40-50
tried 3 different test sites vary slightly but still well below what i pay for
gary_dexter
  • 30.61K
  • 1.9K
  • 4.07K
Message 5 of 7
Re: broadband speed
Wired direct to the hub or via a powerline adaptor/switch etc?
colmick
  • 8
Message 6 of 7
Re: broadband speed
direct to hub still the same
  • 22.51K
  • 2.41K
  • 4.03K
Message 7 of 7
Re: broadband speed
Just wondering whether your March upgrade was actually applied - they sometimes dont get through.
What Hub model is it ?
Go into the "Router Status" pages and look for something like "Configuration File/settings" in there will be 2 boxes - 1 upstream and 1 downstream - labelled "Max Data Transfer Rate" (or similar - Hub dependent) In there will be the max bytes you can get - I am on Vivid200 and mine look like this on my SH2 showing full speed settings .....
