taylorga
Message 1 of 5
broadband speed should be 200mbps only getting 89mbps, tested using Ethernet cable
14027500001.238256 qam30
22027500000.437256 qam9
3210750000037256 qam10
4218750000-137256 qam11
5226750000-1.737256 qam12
6234750000-137256 qam13
7242750000-0.537256 qam14
8250750000-0.238256 qam15
9258750000-0.537256 qam16
16030001248.8512064 qam1
23940000047.3512064 qam4
34619999147.3512064 qam3
45369999347.3512064 qam2
1ATDMA0010
3ATDMA0020
4ATDMA0000
10/06/2021 06:20:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2021 15:06:57criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2021 13:38:12noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2021 13:38:12ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/06/2021 08:53:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2021 14:32:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/06/2021 11:34:13Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2021 20:10:29noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/06/2021 20:10:18Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2021 18:24:57noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2021 18:24:42Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2021 13:01:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
sophist
  • 2.7K
  • 433
  • 747
Message 2 of 5
Re: broadband speed should be 200mbps only getting 89mbps, tested using Ethernet cable
Looks like you have a hub3? Was there more data on the downstream tab? it's only showing 9 channels, there should be 24 ( i think) and also another table below that too.. can you post those..
That said, a ~90mb connection is usually indicative of a dodgy ethernet cable that is only capable of supporting 100mb, or a network card in the device that can only support 100mb - are you able to find out what speed has been negotiated on the connection between the hub and the device you're using?  If it's a windows device you should be able to see this somewhere in hte network connection status/properties
taylorga
Message 3 of 5
one other question, does the Virginmedia hub 3 support NAT Loopback?
sophist
  • 2.7K
  • 433
  • 747
Message 4 of 5
well, there was a thread on the network forum about port forwarding the other day that suggests that NAT loopback is supported.. but i've also seen others say that it isn't. given the user in the thread linked above got it working, it kinda suggests that it is..
Molly_G
  • 1.15K
  • 53
  • 136
Message 5 of 5
Hi @taylorga,
Many thanks for your recent post! I'm very sorry to hear you've been getting poor speeds recently.
How have things been over the weekend? Are you still in need of assistance with this?
If so, let us know and we'll do our best to help.
Kind regards,
Molly_G
