CraigPeters
Settling in
broadband so slow in Wimbledon
Currently in Wimbledon Raynes Park area with terribly slow Broadband and knock on effect to TV services, any body got similar, and or solution - i have done the turn off/on but nothing getting better
DJ_Shadow1966
  • 7.2K
  • 1.37K
  • 2.06K
Re: broadband so slow in Wimbledon
Hello
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Posting the stats by copy and paste will remove all personal information so no breaches.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs (if they are pasted then all personal information is * out) and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connection without either coax or a terminator.
Also please run "Check service status" at the top right of this forum and call 0800 561 0061 to check for local issues.
Also one think you can do is too signup at https://www.thinkbroadband.com/broadband/monitoring/quality and setup a broadband quality monitor which will keep an eye on you connection by sending a small amount of data to the hub asking if it still on.
Regards Mike
CraigPeters
Settling in
downstream Tab
1451000000-20.230256 qam40
2267000000-12.235256 qam17
3275000000-12.735256 qam18
4283000000-13.435256 qam19
5291000000-13.735256 qam20
6299000000-14.734256 qam21
7307000000-13.934256 qam22
8315000000-15.833256 qam23
9323000000-15.733256 qam24
10331000000-15.533256 qam25
11339000000-17.531256 qam26
12347000000-16.533256 qam27
13355000000-18.431256 qam28
14363000000-18.431256 qam29
15371000000-1931256 qam30
16379000000-20.330256 qam31
17387000000-19.730256 qam32
18395000000-21.529256 qam33
19403000000-2030256 qam34
20411000000-20.929256 qam35
21419000000-2129256 qam36
22427000000-19.830256 qam37
23435000000-21.529256 qam38
24443000000-19.531256 qam39
hope this helps
CraigPeters
Settling in
1Locked30.1196183550
2Locked35.790
3Locked35.7130
4Locked35.5240
5Locked35770
6Locked34.324210
7Locked34.91550
8Locked33.8118270
9Locked33.3321020
10Locked33.872790
11Locked31.97823690
12Locked33508810
13Locked31.99175390
14Locked31.612694020
15Locked31.325446670
16Locked30.3147333910
17Locked30.852164460
18Locked29.3409213360
19Locked30.5108774860
20Locked29.4383196000
21Locked29.5335662920
22Locked30.678550260
23Locked29.3392663700
24Locked31.135504100
upstream tab
12580000042512064 qam6
23260000243512064 qam5
33939999843.5512064 qam4
44619999845.5512064 qam3
3ATDMA0000
4ATDMA0000
Config
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
ewrkldJKDHSUBsgvca69834nc
SFID98
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID97
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
network log
03/11/2020 12:20:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/11/2020 08:52:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;31/10/2020 02:22:20noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;31/10/2020 02:22:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:57:36criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:53:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:53:44criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:42:36criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:38:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:38:19Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:37:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:18:1criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:17:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:17:8criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:17:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:17:7criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:17:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:07:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:00:47criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;29/10/2020 02:00:10Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Your Downstream Power Lwevels are far, far too high.Re: broadband so slow in Wimbledon
Your Downstream Power Levels are far, far too low.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
CraigPeters
Settling in
Re: Your Downstream Power Lwevels are far, far too high.Re: broadband so slow in Wimbledon
thank you engineer called for Sat, lets hope to see what they can do
