  • 13
broadband SPEED
FAIRLY NEW   CUSTOMER TO VIRGIN BROADBAND PACKAGE 100 Mbts,  BEST INTERNET SPEED  I GET VARIES BETWEEN 38 TO 52 Mbps WIFI CONNECTION USING VIRGIN SPEED CHECK THE  HUB 3.0 IS ONLY  3 MTRS AWAY  IN DIRECT SIGHT AND I AM THE ONLY USER . EVEN  WITH ETHERNET CONNECTION THERE IS ONLY MARGINAL IMPROVEMENT .  DONE ALL THE CHECKS EVERYTHING COMES BACK AS OK . ANY HELP WOULD BE APPRECIATED
THANKS
  • 14.89K
  • 1.17K
  • 3.48K
Re: broadband SPEED
turn the caps lock off its not needed
what is the wired speed
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
if its an earlier hub button is top right
____________________
Tony
