ikslabuk
  • 7
Message 1 of 13
area 22 speed drop from 200 to under 50
from Christmas the speed drops to 25%, all cables checked, there was a hard reset of the modem
c194879b0532ce1a4a3f20580036f05ca8a767b5-08-01-2021
thank you
Robert
ikslabuk
  • 7
Message 2 of 13
Re: area 22 speed drop from 200 to under 50
now measured speed
Buffer6
  • 11.23K
  • 93
  • 632
Hero
Message 3 of 13
What speed are you getting via OVH  http://www.ovh.net/  ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 13
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
ikslabuk
  • 7
Message 5 of 13
here it is a little better but it's still only half my speed, connected to the router via the cable
https://www.nperf.com/r/3297721630750642-wjPIaJmC
ikslabuk
  • 7
Message 6 of 13
connected to the router with a good cable,
the result is different from the previous test app
reported 'connection speed' is 100Mbps, to other devices it is very low, is it possible to set it or it is the max that was possible to get
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 7 of 13
A rported connection speed of 100Mbs means that the configuration you are testing with will never get above 90Mbs.
What speed is the Network Interface Card (NIC) set at ?
ikslabuk
  • 7
Message 8 of 13
10 Gbps
in my office, it gets speeds of 1Gb on the same laptop
and two weeks ago I had over 200Mbps at home
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 13
Try  different Cat 5e or better ethernet cable and test again.
ikslabuk
  • 7
Message 10 of 13
i use 6 cat cable
it's such a cable
