another gig upgrade slower the previous connection
spacecadetuk
I have just upgraded (10/01/22) to the 1 gig and I have managed to get the Sam knows speed test to work and it doesn't seem like I'm getting the speed to the hub.
I'm basically getting the same as before the upgrade.
Live tbb graph
My Broadband Ping - VM
1 ACCEPTED SOLUTION
Accepted Solutions
@spacecadetuk wrote:
thanks again for looking at this for me
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
54k;fg87dsfd;kfoA,.iyewrk
SFID
32640
Max Traffic Rate
690000278
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
32639
Max Traffic Rate
44000278
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Well there is your answer! You are still configured for 600 Mbps!
Try a full reset on the HUB (30 second press of the reset button).
Keep in mind all settings revert to default.
31 REPLIES 31
spacecadetuk
3.0 Downstream channels
263387500006.40000240.946209QAM25626
11387500008.09999840.946209QAM2561
21467500008.19999740.946209QAM2562
31547500008.09999840.946209QAM2563
41627500006.50000040.366287QAM2564
51707500007.59999840.946209QAM2565
61787500008.40000240.946209QAM2566
71867500008.19999740.946209QAM2567
81947500007.90000240.946209QAM2568
92027500008.09999840.946209QAM2569
102107500007.90000240.366287QAM25610
112187500007.80000340.946209QAM25611
122267500007.69999740.366287QAM25612
132347500007.59999840.366287QAM25613
142427500007.90000240.366287QAM25614
152507500007.80000340.946209QAM25615
162587500008.09999840.366287QAM25616
172667500007.59999840.946209QAM25617
182747500007.00000040.946209QAM25618
192827500007.00000040.366287QAM25619
202907500007.09999840.366287QAM25620
212987500007.80000340.366287QAM25621
223067500007.30000340.366287QAM25622
233147500006.90000240.366287QAM25623
243227500006.00000040.366287QAM25624
253307500006.50000040.366287QAM25625
273467500006.50000040.366287QAM25627
283547500006.80000340.946209QAM25628
293627500006.80000340.946209QAM25629
303707500006.80000340.366287QAM25630
313787500007.00000040.946209QAM25631
26Locked40.94620930
1Locked40.94620900
2Locked40.94620900
3Locked40.94620900
4Locked40.36628700
5Locked40.94620990
6Locked40.94620900
7Locked40.946209640
8Locked40.94620910
9Locked40.94620900
10Locked40.36628700
11Locked40.94620910
12Locked40.36628710
13Locked40.36628710
14Locked40.36628700
15Locked40.94620900
16Locked40.36628700
17Locked40.94620900
18Locked40.94620900
19Locked40.36628700
20Locked40.36628710
21Locked40.36628710
22Locked40.36628720
23Locked40.36628720
24Locked40.36628710
25Locked40.36628710
27Locked40.36628760
28Locked40.94620980
29Locked40.94620960
30Locked40.36628730
31Locked40.94620930
3.1 Downstream channels
159944K1840QAM4096424
159Locked436.14101212860
Live tbb graph
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
Live tbb graph
Very odd as the stats and BQM look pretty good! Power levels on downstream a touch high but in spec. Anything in the Networklog tab? Oh could you post the upstream tab data also?
The only difference I've noted, when compared to mine, is the 'Channel Width', 'Number of Active Subcarriers', and First Active Subcarrier' are different values:
Mine:
159964K1880QAM4096759
Yours:
A bit over my head if this would make a massive difference to your connection!
thanks for the reply, I'm not sure if its been upgraded to be honest.
here is the network log
TimePriorityDescriptionThu Jan 1 00:01:17 19703No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 18:33:51 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 18:33:51 20223Registration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 18:33:51 20224T6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 18:33:52 20223REG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 18:34:20 20223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 18:34:45 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 18:34:58 20226SW Download INIT - Via Config file a69834ncxv9873254k;fg87dsTue Jan 11 18:36:11 20226SW download Successful - Via Config fileTue Jan 11 18:38:43 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 19:06:04 20224DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 19:06:05 20226DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt078-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 20:04:52 20224DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 20:04:52 20226DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt078-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Tue Jan 11 21:47:24 20226CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Wed Jan 12 12:44:43 20223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;Wed Jan 12 19:18:06 20225MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
upstream stats
3.0 Upstream channels
14620000043.0205995120 KSym/sec64QAM1
22580000042.2705995120 KSym/sec64QAM4
33260000042.2705995120 KSym/sec64QAM3
43940000042.2705995120 KSym/sec64QAM2
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
Live tbb graph
I am maxing out my connection from the router, it's the speed to the hub that's the issue I think.
Live tbb graph
That's a good point (Upstream looks healthy btw)!
What does your configuration tab look like?
Network access
true
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
87dsfd;kfoA,.iyewrkldJKDH
SFID
889
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
1420
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
16320
Scheduling Type
bestEffort
Network access
true
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
SFID
32640
Max Traffic Rate
690000278
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
32639
Max Traffic Rate
44000278
Max Traffic Burst
42600
Min Traffic Rate
0
42600
Scheduling Type
bestEffort
I don't know anything about these stats but the max traffic rate looks the culprit to me?
Live tbb graph
Network access
true
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
SFID
32640
Max Traffic Rate
690000278
Max Traffic Burst
42600
Min Traffic Rate
0
SFID
32639
Max Traffic Rate
44000278
Max Traffic Burst
42600
Min Traffic Rate
0
42600
Scheduling Type
bestEffort
Thanks.
I take if that doesn't work it's a phone call to customer services :☹️
Live tbb graph
