BennyBiscuit
Xbox download speed terrible
Hi there, when I run the network speed test via my Xbox settings I am getting circa 400mps download speeds. However, when downloading games it is only circa 30mps? I can’t understand the difference?
I have a hard wired connection.
thanks
ben
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: Xbox download speed terrible
Games consoles are notorious for speed tests.
What is your connection like using a direct connection with a Cat 5E or better ethernet cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook ?
Avalon-One
  • 8
Speedtest tests your connection speed to/from the speedtest server with the lowest ping, downloads are from the Xbox Live servers... at Christmas... in the midst of a pandemic lockdown for the majority of the UK and following a new console launch, it's easy to see why one of those would be significantly different from he other.
