on 12-10-2023 20:49
Virgin Media have just finished works in my area and I signed up pretty sharpish. An engineer has come round, ran the fibre to where I wanted it and I’ve been hooked up to the new XGS-PON network with a Hub 5x.
I’m wondering if there’s a known “settling in” period where it takes a period of time to get the advertised speeds? I’m guessing it should be pretty instant in terms of getting the advertised speeds.
When the engineer came round and installed it, I was getting around 1-1.2Gbps. However now it seems to have dropped to 650-900Mbps.
on 12-10-2023 20:58
There is no ‘settling in period". How are you measuring the speed?
on 12-10-2023 21:01
I thought as much!
Either with Speedtest.net or Fast.com with my iPhone 14 Pro sat right next to the router. There’s no other devices taking up any other bandwidth.
on 12-10-2023 21:12
on 12-10-2023 21:32
Your testing via WiFi so your tests are not accurate, 900mb Is insanely fast over wifi
on 12-10-2023 21:41
Hence the reason for checking the speed to the HUB!
on 12-10-2023 22:19
Interesting, I didn’t know about this tool! So speeds to the Hub look really good (I’m intrigued to know how this can actually be tested). These speeds are certainly nothing much to complain about, I agree, but I’d certainly expect to be pushing nearer the top end more consistently.
12-10-2023 23:16 - edited 12-10-2023 23:18
image doesnt work, but i guess its the samknows test, it just has the software built into the router to test it properly 🙂
on 15-10-2023 10:33
Hi @Recoil13 👋.
Thanks for reaching out to us and welcome to the Community Forums. Apologies for the delay in responding, we kind of do have what is known as a settling in period, it is more where we do let the speeds build up to their optimum rather than just hammer full speed at a new device, so it can go up and down. You will get varied speeds over WiFi connection but we do have our guideline thresholds that do define what would be regarded as slow speeds, but for any guaranteed speeds we always advise this over a wired connection rather than wireless.
I hope this helps.
Sabrina
on 15-10-2023 10:43
"we kind of do have what is known as a settling in period, it is more where we do let the speeds build up to their optimum rather than just hammer full speed at a new device, so it can go up and down."
How is this managed then? Does some dedicated VM employee manually taper, on an individual hub by hub basis, the "Max Traffic Rate" value in the hub's Config files to delicately ease the hub in? A beautiful vision and one to cherish.
