Lupinsorbet
  • 8
Message 1 of 7
Wrong Upload Speed
Hello Community,
I just noticed that with a M200 contract I should have 20mbps. We got the speed upgrade from a M100 package and I always had 5mbps upload, but with working from home this is a bit thin. Looking at the speed table https://www.virginmedia.com/shop/broadband/speeds I should have 20mbps.
Has anybody here had the same experience?
Best regards!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 7
Re: Wrong Upload Speed
Can you please
Copy and paste the contents of the Configuration tab onto here, if you get a yellow warning click the Post button again.  Please do not use screen grabs.
Lupinsorbet
  • 8
Message 3 of 7
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxl20016u-b.cm
SFID405948
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID405947
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 7
Your Hub is set at the correct speeds.
How are you speed testing Wi-Fi or ethernet cable connected device ?
SFID405948
Min Traffic Rate0
SFID405947
Min Traffic Rate0
Lupinsorbet
  • 8
Message 5 of 7
Hi Mike,
your confirmation that Hub has correct settings made me think and I remembered there was a max upload/max download setting in my FritzBox that was still set to the original upload of 5mbps. I upped that limit to 25 and now I have the full 20mbps upload.
Thanks a lot for your help.
Best regards!
  • 16.28K
  • 711
  • 1.6K
Message 6 of 7
Your QoS limit will not work with it set to 25 as the FritzBox will just be going not hit the limit, not hit the limit...and the hub will buffer all your packets into a single queue so set it to 19.
Lupinsorbet
  • 8
Message 7 of 7
Hi Alessandro,
the 25 was more for testing purposes to check maximum upload speed. I have set it now to 19 going forward. Thanks for your advise.
Best regards!
