holdensredhat
  • 16
Message 1 of 21
Worse DL Speed after supposed boost to 350
Please can anyone explain why my dl speed is worse after a boost?
My Contract was M200 and I was getting that, now after a boost to M350, I am getting less than 100 and there is no consistency at all. It's really up and down but never hitting the correct speed, not even by their margins of acceptable speed. However, the upload speed has increased in line with the boost though. I am in the M22 area.
Would appreciate any ideas or advice.
Thanks in advance
David
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 21
Re: Worse DL Speed after supposed boost to 350
Which Hub do you have ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 3 of 21
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 21
Can you please
holdensredhat
  • 16
Message 5 of 21
I have a Hub 3.
Now this is bizarre, having posted the question, there seems to have been a miracle!
My dl speed is now being recorded as 301 and ul as 35.95.
This is radically different to an hour ago?!
Not sure why.
Thank you for replying. I am going to keep an eye on it.
Cheers Again.
holdensredhat
  • 16
Message 6 of 21
2987500005.340256 qam21
2138750000640256 qam1
31467500005.638256 qam2
41547500005.540256 qam3
51627500005.140256 qam4
61707500004.940256 qam5
71787500004.640256 qam6
81867500004.538256 qam7
91947500004.438256 qam8
10202750000438256 qam9
112107500003.738256 qam10
122187500003.538256 qam11
132267500003.438256 qam12
14234750000338256 qam13
152427500002.538256 qam14
162507500002.238256 qam15
17258750000338256 qam16
182667500003.738256 qam17
192747500004.138256 qam18
202827500004.840256 qam19
21290750000540256 qam20
223067500005.440256 qam22
233147500005.540256 qam23
243227500005.440256 qam24
1Locked40.322489745
2Locked40.31140356348030
3Locked38.91561627688800
4Locked40.31523210991163
5Locked40.324834381060661
6Locked40.316273741734635
7Locked40.34543427221501
8Locked38.938933330749
9Locked38.9329410319
10Locked38.9287911170
11Locked38.9272410686
12Locked38.9296513344
13Locked38.6299410873
14Locked38.934297984
15Locked38.936767688
16Locked38.9341711658
17Locked38.9298511508
18Locked38.927179698
19Locked38.927297328
20Locked40.318936570
21Locked40.317957884
22Locked40.322919916
23Locked40.314396466
24Locked40.314715317
holdensredhat
  • 16
Message 7 of 21
13940000444512064 qam12
24620000445.3512064 qam11
35370001446.8512064 qam10
46030006347.3512064 qam9
1ATDMA0010
3ATDMA0010
4ATDMA0000
holdensredhat
  • 16
Message 8 of 21
etwork access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
sgvca69834ncxv9873254k;fg
SFID868
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID867
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
holdensredhat
  • 16
Message 9 of 21
5/11/2020 16:26:0Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:36:30Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:20:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:20:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:13:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:13:44criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:13:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:13:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:13:37Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 06:32:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 02:53:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 18:02:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 18:45:25Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 18:45:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 18:45:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 18:45:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 18:45:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 18:45:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 18:45:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 18:45:13criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 10 of 21
Your Pre & Post RS Error counts are very high.
In an ideal world they would be at zero and stay there. To zero them can you reboot the Hub using this method and then keep an eye on the counts.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check the counts again in an hour or so.
