on 05-12-2023 17:07
Hope someone can help I am enthernet cables from my Router to my PC only 2foot apart, I am getting 1145mbps to my router by only getting 245 to 300 mbps to my pc, this only just started happening, done virus checks maleware checks nothing detected, changed enternet cable cat 6 still the same, has anyo0ne had this problem, any sujestions how to get my top speeds back to my pc. One other thing useing Chrome checked updates, this is also happening with Microsoft Edge
on 10-12-2023 17:15
Did this PC by any chance not have the ethernet port in use for a while, as in did you start to use it recently and then the issue started? I once had similar on a machine and it turned out the ethernet port at the back of the PC had a fair amount of dust which resulted in poor contact with the ethernet cable.
on 10-12-2023 19:09
Yes is been in the port for a while before it started happening, it was working fine then started happening all of a suden
on 10-12-2023 22:24
What happened when doing the speedtest as I suggested ?
on 11-12-2023 06:30
Sorry forgot to put that I had 1145 mpbs to the hub 295 mpbs hard wired from hub to pc and 325 mpbs wireless not bad speeds and they are roughly the same every time do a test. but was getting before 945 plus mpbs
