alysonfds
  • 9
Message 1 of 17
Wifi
I have subscribed for 350mbps but the speed is very slow and i also did the test on the virgin site and it shows only 2Mbps.
I followed all the steps that i found on the virgin website but unable to solve the issue. I also called the customer service so many time but even after being on call for 45 min there is no answer.
Appreciate if someone can help/guide me to this resolved.
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 17
Re: Wifi
What speed do you get using a direct connection using a Cat 5E/6 cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
alysonfds
  • 9
Message 3 of 17
Re: Wifi
we are using a fibre cable provided by Virgin and when we tested the speed it is the same which is 2Mbps . We do not have the Cat 5E/6 cable
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 17
Re: Wifi
Until you can determine the broadband speed coming into the Hub you don't know whether you have a broadband problem or a Wi-Fi problem.
VM do not guarantee Wi-Fi because there are far too many external influences that can spoil the Wi-Fi broadcast from the Hub.
alysonfds
  • 9
Message 5 of 17
Re: Wifi
Sorry the ethernet cable is the CAT 6 cable and we have tried connecting to the laptop and did the speed test. The speed still shows as 2mbps.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 17
Re: Wifi
Then
Can you please
alysonfds
  • 9
Message 7 of 17
Re: Wifi
Alyson Wifi direct link url
Downstream tab
1419000000136256 qam30
21870000001.737256 qam7
31950000001.537256 qam8
42030000001.537256 qam9
52110000001.736256 qam10
62190000001.936256 qam11
7227000000237256 qam12
82350000001.736256 qam13
92430000001.736256 qam14
102510000001.537256 qam15
112590000001.537256 qam16
122670000001.237256 qam17
13275000000137256 qam18
14283000000137256 qam19
15291000000137256 qam20
16299000000137256 qam21
173070000000.737256 qam22
183150000000.937256 qam23
193230000001.237256 qam24
203790000001.537256 qam25
213870000001.537256 qam26
223950000001.237256 qam27
23403000000137256 qam28
24411000000136256 qam29
1Locked36.61100
2Locked37.3400
3Locked37.6190
4Locked37.6710
5Locked36.6640
6Locked36.3410
7Locked37.3590
8Locked36.6850
9Locked36.6250
10Locked37.3300
11Locked37.6550
12Locked37.3170
13Locked37.3490
14Locked37.6650
15Locked37.3400
16Locked37.6360
17Locked37.6870
18Locked37.3530
19Locked37.3440
20Locked37.6340
21Locked37.6440
22Locked37.61040
23Locked37.3490
24Locked36.6810
alysonfds
  • 9
Message 8 of 17
Re: Wifi
1603002864.525512064 qam1
2394001364.425512064 qam4
3537002884.5512064 qam2
4462004194.5512064 qam3
3ATDMA0000
4ATDMA0000
03/10/2020 14:30:58noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/10/2020 06:34:4ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/10/2020 21:33:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 19:58:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 12:49:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 12:49:7criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 12:49:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 12:49:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 12:48:51Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 12:48:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 12:48:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/09/2020 12:48:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 13:37:41noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 13:14:46noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 13:14:5Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 12:25:33noticeUnit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/09/2020 12:23:1noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 9 of 17
Re: Wifi
Your Hub data is all looking good.
Up to now your >> BQM << is as bad as it gets but leave it a few hours to see how it develops.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues
alysonfds
  • 9
Message 10 of 17
Re: Wifi
Checked both below:
Have you checked the 'Check Service Status' at the top of the page ? No Issues
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues - No Issues
