So here we have it, I have the vm boosters that was sent, however they don’t indicate to which they are actually are, if wired or the WiFi booster as the leaflet states either 1 or the other. So from all the previous feeds had issues, so over night slept on this and said ok, options.
1st. move the router ?
not possible as need the Ethernets
2nd. Let’s try and see what This WiFi button does on the larger booster
Ok that did something as speed just went up in the room with issues
3rd. Try the work computer and see if changes from weak signal back to medium signal
so far back on medium signal
4th. RIP out and cancel virginmedia as service is shocking
last resort
