Off_switch
  • 91
  • 15
Up to speed
Message 1 of 5
Wifi using Hub3
My techi son staying during lockdown has found that in the same room as my hub3, speeds were 83mbps.
But go elsewhere, it drops. Significantly.
How can I boost the signal so he can work upstairs and get good speed?
gary_dexter
  • 31.3K
  • 1.94K
  • 4.2K
Message 2 of 5
Re: Wifi using Hub3
Get a better router or mesh system and put the hub into modem mode.
  • 23.98K
  • 2.54K
  • 4.35K
Message 3 of 5
Re: Wifi using Hub3
Get your own better quality wireless equipment.
VM will offer a booster - if its free its worth a try - if they want to charge you £3/mo it isn't.
Off_switch
  • 91
  • 15
Up to speed
Message 4 of 5
Re: Wifi using Hub3
Thanks!
But which device to get. I mean whats a mesh?
  • 23.98K
  • 2.54K
  • 4.35K
Message 5 of 5
Re: Wifi using Hub3
Bit like asking which car should I get 🙂
For Mesh info see....
https://www.techadvisor.co.uk/test-centre/network-wifi/best-mesh-wi-fi-network-systems-3661110/
Are you sure its just a wifi issue - if you connect via ethernet cable are speeds better and connections stable ?
